How Can the Superposition Principle Help Solve an ODE with Initial Conditions?
In summary: If I'm not mistaken, it will become 3* e^{-1.3t} - 4* e^{-1.3t}and the final answer is 3 * e^{-1.3t}In summary, the solution for x(t) if x(0)=3 is 3e^(-1.3t). The general solution of the given differential equation is Ce^(-1.3t), which can be found by integrating the related problem dy/dx = -1.3y and applying the given boundary condition. The solutions x1(t) and x2(t) can be recognized as special cases of the general solution.
shinnsohai
41
Given
[itex]\frac{dx}{dt}[/itex] = -1.3x
[itex]x_{1}[/itex](t)=e[itex]^{-1.3t}[/itex]
[itex]x_{2}[/itex](t)=4e[itex]^{-1.3t}[/itex]
Compute a solution for x(t) if x(0)=3
and some ODE related
Anyhow I refer to this
http://www.youtube.com/watch?v=_ECd0Jn7y68
First Attempt
x(t)=[itex]\alpha[/itex] (e[itex]^{-1.3t}[/itex]) + [itex]\beta[/itex] (4e[itex]^{-1.3t}[/itex])
[itex]\frac{dx}{dt}[/itex]= (-1.3) * ([itex]\alpha[/itex] [itex]x_{1}[/itex] + [itex]\beta[/itex] [itex]x_{2}[/itex] )
Then after this step, I've no idea how to continue, I am stuck here, what Should I do with the given initial condition? x(0)=3
I've done some google search, some ODE with Initial condition provided
Perhaps Related Solution:
[itex]\frac{dy}{dx}[/itex] = -1.3x
[itex]\int[/itex] 1 dy = [itex]\int[/itex] -1.3x dx
To get the Constant, I've plugged in the given initial condition x(0)=3
y = [itex]\frac{-1.3x^{2}}{2}[/itex] + c
c = -5.58
Re-arrange the eqn
y= [itex]\frac{-1.3x^{2}}{2}[/itex] - 5.58
after getting this?
how do I proceed ?
Imma so confusee!(Sorry Mods, It's quite sometime I dint visit the forum, Making such messy mistake on the previous post)
Anyway
Here's the (Hand written working LINK)
http://imgur.com/VmfPJwr
http://imgur.com/J5k5YeO
I'm not that familiar with the Latex Code :-p
shinnsohai said:
Given
You're making this much more difficult than it actually is. Do you know what the general solution of your differential equation is? Assuming that you do, just use your initial condition to find the solution for which x(0) = 3.
First Attempt
This is not at all related to your problem. A related problem would be dy/dx = -1.3y.
c = -5.58
Re-arrange the eqn
after getting this?
how do I proceed ?
Imma so confusee!
Anyway
Thanks Mark for replying
I've messed up the thing eventually
Based on the related problem dy/dx = -1.3 y
Integrate it
and
apply the boundary condition x(0)=3
[itex]\int[/itex] [itex]\frac{dy(x)}{dx}/{y(x)}[/itex] = [itex]\int[/itex] -1.3 dx
log(y(x)) = -1.3x +c
y(x) = [itex]e^{-1.3x+c}[/itex]
Let C = [itex]e^{C1}[/itex]
y(x) =C * [itex]e^{-1.3x}[/itex]
Plug in the Given boundary
x(0)=3
3 = C * [itex]e^{0}[/itex]
C=3
Re-arrange
y(x) =3* [itex]e^{-1.3x}[/itex]
So until this step
what should I do with the
Yes, that's it, although you should write your answer as x(t) = 3e-1.3t. In your diff. equation, x was the dependent variable and t was the independent variable.
I believe that what they wanted you to do with x1(t) and x2(t) was to recognize that all solutions are of the form Ce-1.3t.
Likes 1 person
So until this step
You need to decide whether your independent variable is ##t## or ##x##. What happens if you calculate ##x_2 - x_1##?
Likes 1 person
Oh ya!
I used to use dy and dx
and now i get messed up again!:-p
Thanks for remind that!
Related to How Can the Superposition Principle Help Solve an ODE with Initial Conditions?
1. What is an ODE with Superposition?
An ODE (Ordinary Differential Equation) with Superposition refers to a type of differential equation where the solution can be obtained by adding together the solutions of simpler differential equations. This is useful in solving complex problems where the differential equation cannot be solved directly.
2. How does superposition work in ODEs?
Superposition works by breaking down a complex ODE into simpler ODEs that can be solved individually. The solution to the complex ODE is then obtained by adding together the solutions of the simpler ODEs. This is possible because of the linearity property of ODEs.
3. What is the significance of superposition in ODEs?
Superposition is significant in ODEs because it allows us to solve complex problems that would otherwise be difficult or impossible to solve. It also provides a systematic and efficient approach to solving linear ODEs.
4. Can superposition be applied to all types of ODEs?
No, superposition can only be applied to linear ODEs. Non-linear ODEs do not have the linearity property and therefore cannot be solved using superposition.
5. Are there any limitations to using superposition in ODEs?
Yes, there are limitations to using superposition in ODEs. It can only be applied to linear ODEs, and even then, it may not always provide an exact solution. In some cases, superposition may only provide an approximate solution or may not work at all.
  • Math POTW for University Students
