How can time only have one direction?
  • Context: Undergrad
  • Thread starter Thread starter student34
    Direction Time
105 replies · 7K views
student34
A basic example to explain what brings about my question is when considering two objects moving away from each other with an object at rest in the middle. In all 3 objects' frames of reference they are going through their respective time axises at the speed of light.
It would appear that time has at least 3 directions in this example. Can someone help me understand how time has only one direction?
Time is a scalar but you're trying to treat it like a vector. Localized time is called "proper time" and always moves forward at one second per second (regardless of how it might look to some non-local observer).
student34 said:
I would appear that time has at least 3 directions in this example. Can someone help me understand how time has only one direction?
None of these are "directions of time"; the concept "direction of time" doesn't have a well-defined meaning.
What you have here are three different timelike curves, with three different timelike tangent vectors (vectors parallel to the curves) at the point where they meet (the common spacetime origin of the three rest frames of the three objects). The three different timelike tangent vectors define three different timelike directions in spacetime at the given point.
The idea that objects "move at the speed of light" in their own rest frame is rather meaningless. It sounds good in a pop science video. But that is about it. Objects have 3-velocities of zero in their own rest frames. Four-velocities have a fixed norm by definition. The fact that the norm is what it is says nothing about the four velocity.
But that is not what you ask about.
Let us take your three objects. Each of them has a timelike trajectory (like all massive objects). We assume that the three trajectories share a common intersection event. You express surprise that the three trajectories each share a common general direction in time.
But that is silly. There were six trajectories to choose from. You could have chosen the half-trajectory for object a going toward the intersection from the past or the half-trajectory for object a going away from the intersection into the future. The same for objects b and c. But you imply that you have chosen the three half-trajectories going into the future. Those are all future-directed because you chose them that way.
Presumably you have chosen to work in a spacetime that is time-orientable so that a clear distinction between future and past light cones anywhere can be extended unambiguously through the rest of spacetime everywhere else. [I think this is a consequence of time orientability]
See https://arxiv.org/pdf/gr-qc/0202031.pdf which goes a bit above my comfort level.
It's the definition of time orientability. Pretty much all other properties used by physicists assume a time orientable spacetime.
From section 4 of that paper:
Hadley said:
It is not possible to define a spinor field on a non-time orientable spacetime [8 (Geroch)].
Since fermions exist, this well-known result has been cited as evidence that time must be
orientable.
So far, so good. But then... (with my emboldening]:
However the argument relies on a realist interpretation of the wavefunction and the false assumption that a wavefunction is defined at each spacetime point. In fact a wavefunction is a function defined on a 3N-dimensional configuration space where, N, is the number of particles.
Hadley does not justify the statement shown in bold above. Indeed, spinors are known to be just as physically real as, say, vectors. Imho, his invocation of wavefunctions here is spurious.
We usually call the things that the three objects have that are different "4-velocities", but it is correct to say that each of the 4-velocity represents the time axis of the corresponding frame of reference, and it is also correct to say that they are all different.
It is also correct to say that the 4-velocites are all different and are not the same. I'm not quite sure why you think they should be or need to be the same.
"Time" can have a lot of meanings, it can be confusing to pick the right word to prevent ambiguities.
Possibly you expect there to be a "future" and a "past", and that's why you think that time should have only one direction? I'd say that it's better to model that concept with light cones, in which case you do have only two light cones, a future light cone and a past light cone. In special relativity and in most reasonable GR geometries, there is a common and global notion of "past" and "future" light cones, but things can get more complicated in some screwy GR geometries.
strangerep said:
From section 4 of that paper:So far, so good. But then... (with my emboldening]:
I never understood this discussion about many-body states in the position representation. Also in classical point-particle mechanics the configuration space of ##N## particles is ##3N## dimensional, i.e., you have functions of configuration-space variables and their time derivatives as observables and "states" in statistical mechanics are phase-space-distribution functions of ##6N## phase-space variables.
Why then is it so strange that in quantum mechanics we have wave functions with ##3N## configuration-space arguments?
Of course in relativistic QFT we don't have wave functions with a fixed number of particles but quantum fields and Fock states of (asymptotic) free particles.
The orientationability of time is just taken as an axiom in all of physics, i.e., there's a past and a future light cone containing the events "in the past" which can be causes to an event or for which the event in question can be the cause for an event "in the future". In SR that's globally in GR in general only locally defined.
Agreed. Geroch's argument is about Spinor fields, which are either operators in the quantum theory or just fields in the classical case. Nothing to do with wavefunctions.
Then it would seem to me that time has more than one dimension. With the example in mind, time appears to be able to intersect with itself. I don't know the exact definition of a 2d space, but if it can intersect with itself everywhere and be parallel with itself everywhere, then doesn't that mean that it has at least 2 dimensions?
And I suppose I am assuming that spacetime is continuous. I believe that Einstein made this claim, but I do not know if it is assumed in the standard view of spacetime today.
Time is one dimension. How can a dimension have more than one dimension? Could length have more than one length?
student34 said:
It would seem to me that time has more than one dimension.
No. You are mixing up several uses of the word "time" and getting confused. When you are talking about the proper time along a worldline, as you appear to be doing here, time is just a scalar and doesn't really have a "direction" per se. The worldline has a direction, its tangent vectors have directions, but the proper time doesn't.
This is a very different use of "time" from the dimension, which is just one of the dimensions in spacetime. That doesn't have a direction either.
A third usage of the word "time" is coordinate time, which is part of a coordinate grid we superpose on spacetime. That does (sort of) have a direction, at least in the sense that the associated basis vectors are everywhere defined and have direction. But different frames define different directions that they call time. This still doesn't mean that time has more than one dimension, any more than the fact that the direction you call forward and the direction I call forward may be different implies that forwards is not a direction but a plane.
In my post, I tried to explain how the worldlines of time appear to fill a space.
I understand what you are saying, but I still come to the same conclusion as in my post. The worldlines of time seem to fill a 2d space, don't they?
This is nonsense. Time does not have worldlines - objects (and light) have worldlines.
I meant the worldlines that occupy time.
Note that your conclusion would also apply to Galilean/Newtonian physics.
(Note: A spacetime diagram is a position-vs-time diagram.)
A set of worldlines occupy space as well, and it's the combination of space and time that is multi-dimensional. A "congruence" is the term used when you are filling spacetime with a set of worldlines, and it's a standard GR tool. It doesn't mean "time is more than one dimension".
Interpreted literally, that is nonsense. World lines do not "occupy time". But I think that I understand. It amounts to a choice of coordinate system.
You imagine space time as a the collection of all events on a family of parallel world lines? Like a set of parallel hairs filling a volume?
But I can imagine the same space time as a collection of all events on a different family of non-intersecting worldlines all sharing a different common direction. Neither imagining is more valid than the other.
Different coordinate systems covering the same space-time can make different choices for the direction corresponding to world lines with fixed spatial coordinates.
Yes, but isn't spacetime considered to be 4 dimensions? We still need space don't we?
Like I said, I do not know the exact definition of a dimension, but the light cone seems to fill a 2d space. Since this is already known, I would like to know why it does not meet the criteria of a 2d space.
It does. In fact the interor of a lightcone is a 4d space (only 2d are shown on a Minkowski diagraml. But this has nothing to do with time.
Yes... so our diagram is (d+1)-dimensional for d spatial dimensions,
which can [and is] also done for Galilean/Newtonian kinematics.
My point is your comments aren't restricted to special or general relativity,
they also appear in Galilean relativity.
In other words, forget special relativity... do you have a problem with Galilean relativity?
How could non of them intersect?
I meant the worldlines in a light cone.
How could none of what intersect? You have populated spacetime with a bunch of world lines. You say that these world lines fill it. If they intersect, you've done the tesselation inefficiently.
I only want to focus on special relativity for now.
You said, "But I can imagine the same space time as a collection of all events on a different family of non-intersecting worldlines all sharing a different common direction.".
Worldlines don't "occupy time". They are curves in spacetime.
I think you need to take a big step back and think carefully about what you actually mean by the word "time". I suspect, as @Ibix said in post #12, that you actually mean several different things but are treating them as if they were the same. That's only going to confuse you, as indeed it seems to have done.
Then I think you need to take another big step back and think carefully about what you actually mean by "dimension".
You can't expect to reason well if you don't even understand the words you are using.
