Mentor
- Messages
- 51,193
- Reaction score
- 27,210
"Time axis" is a property of frames, not objects. So this question is unanswerable as you ask it.student34 said:Using the example in the OP, the object in the middle would calculate the time axis, of the objects moving away from it, pointing in different directions, no?
I could try to guess what you actually mean, but I won't. Instead, you need to rephrase your question so it makes sense. It is very frustrating that, even after multiple threads with you on topics like this, you are still unable to use standard terminology in a standard way.
This is all nonsense, and the reason why has already been explained to you. There is no point in continuing to go around in circles.student34 said:I would think that the time and space axis would have to be fixed if time is not going to point in a different direction for other observers in motion. Again, the example I gave would seem to have 3 different directions of time.
Objects don't have light cones. Events do. So this is nonsense as you state it.student34 said:The worldlines of other objects seem to be able to fill an object's light cone
See my remarks above about rephrasing things so they make sense and using standard terminology in a standard way.
Nonsense. You've already been told why.student34 said:using multiple time axis.
Nonsense. You've already been told why.student34 said:This seems to give time 2 dimensions, or space instead of just a line.
Then what's the point of further discussion? How many times do we have to see you making the same errors and giving you the same corrections?student34 said:I agree with what you are saying, but I still don't see it resolving my issue.
Then why can't you answer the question you've already been asked, multiple times, by giving whatever "good idea" you have?student34 said:I do not know the rigorous definition of a dimension. I believe that I have a good idea though.
