How can you actually measure the electron position?
13 replies · 6K views · last reply
Tomishiyo
Standard quantum mechanics text-books discusses Born rule, which states that the probability of finding a particle in a certain region in space is given by
$$ |\Psi ({\bf r},t)|^2d^3r $$
Thing is, I never have seen a discussion about how you can actually measure the particle position in a given system. Do you use x-rays? How the experiment actually works? Can you refer me to papers about it or describe the experiment with details?
You can let the particle run into a photographic plate which produces a dot at the point of impact. Or you can shine light on the particle and look for reflections/scattering. That sort of thing.
As has been stated, you let an electron hit a screen that will leave a mark or a signal. I can also make a very small slit, and if I detect a signal after the slit, I know that the electron passed through that position where the slit is. The uncertainty in the position corresponds to the width of the slit.
Zz.
Zz.
I think the OP meant the position of the electron in an atom.
This is the OP's post (my emphasis)
Nowhere in there is there any indication that this is only for within an atom.
Zz.
Zz.
That is why I said I think, because he said "in a given system", atoms being the more interesting case. But anyway the OP himself can clarify if he wishes.
"Interesting" is subjective. Electrons in a Luttinger Liquid system is more interesting to me. Yet, I try not to impose what I find "interesting" to the question.
Zz.
Zz.
And yet, if you let a photon go through the same slit and detect it, you haven't measured its position. Or so I'm told.
I have too! At the moment that photon passed through that slit, where do you think it is? 20 miles away?
I have dealt with this in my explanation of the HUP in another post
https://www.physicsforums.com/threads/misconception-of-the-heisenberg-uncertainty-principle.765720/
... or so I'm told.
Zz.
He is referring to the fact in QED for a photon position is not an observable.
http://arnold-neumaier.at/physfaq/topics/position.html
'The POVM does not allow one to talk about the position of a photon - which could exist only if the corresponding operator existed -, but only about the measured position: The photon is somewhere near the range of values established by the measurement, without any more definite statement being possible.'
In other words you can localise its field but getting an exact position is problematical.
Thanks
Bill
Thanks
Bill
But within the context of this thread, i.e. the OP is asking how one actually measures the position of a particle, it is the act of measurement and the experiment that matters. As I've said, I can localize the position of a photon or an electron when it passed through such a slit. A whole slew of experiments depend on that being true. Otherwise, a lot of things will go wrong with our measurements.
Zz.
Hi Zapper
For sure.
Thanks
Bill
Why 20? ...if he were wrong, then one would have been enough... :oldeyes:
Thank you all for your answers, and apologies for my delayed answer.
I was not thinking only about atoms, but it would be interesting to know how the experiment is done in this case. Also, does anyone knows any paper describing one of such experiments?
