How can you find this differential equation?
The discussion centers on deriving a differential equation related to chemical potentials in a binary system, specifically using the Gibbs-Duhem equation. The participants clarify the relationship between the chemical potentials μA and μB, with the equation nB dμB = -nA dμA being pivotal. The integration of both sides leads to the conclusion that for a binary system, the relationship simplifies to dμB/dμA = -xA/(1-xA). This establishes a clear mathematical framework for understanding the behavior of the components in the system.
  • Understanding of Gibbs-Duhem equation
  • Familiarity with chemical potential concepts
  • Basic knowledge of derivatives and integration
  • Concept of mole fractions in binary systems
  • Study the Gibbs-Duhem equation in detail
  • Learn about chemical potential and its applications in thermodynamics
  • Explore integration techniques for differential equations
  • Investigate the implications of mole fractions in chemical equilibria
Chemistry students, chemical engineers, and anyone studying thermodynamics or chemical equilibria will benefit from this discussion.
Lamebert
This is actually a chemistry problem, but I feel it's more appropriate posted here, as I'm not having trouble with the chemistry but rather the mathematics. To avoid mixing subjects, I'll keep chemistry jargon out.
We're given the formula for a component, and the problem request we give another component (which happens to be the derivative of the component given).
Given formula: GT = C + RTln(xA)/xa
where C, R, and T are constants for our purposes. (For clarity, A and B are different substances. Normal script T is temperature and subscript T is total, or the additive of components A and B for that variable)
In the case of the problem, the component xA = nA/nT
and μA = ∂GT/∂nA
So, solving for μA, we get μA = RT(1-ln(xA / xA2nT)
Now, onto my question. A certain equation says that
nBB = -nAA
And the problem requests I find a differential equation to solve for μB, but the required integration doesn't make sense to me. I mean, I assume I'm supposed to integrate both sides using the previously solved for μA. But I haven't taken a differential equations class, so I'm not sure how to produce a differential equation for this relation using the information given.
Any help would be appreciated. Thanks.
I don't see that. Is there some confusion in the subscripts between captial A and lower case a ?G_T = C + \frac{R\ T}{x_a} ln{(x_A)}
x_A = \frac{\eta_A}{\eta_T}
G_T = C + \frac{R\ T}{x_a} ln{( \frac{\eta_A}{\eta_T})}
\mu_A = \frac{\partial G_T}{\partial \eta_A}
= \frac{R\ T}{x_a} \frac{1}{ ( \frac{\eta_A}{\eta_T}) }\frac{1}{\eta_T}
= \frac{R\ T}{x_a}\frac{1}{\eta_A}= \frac{R\ T}{x_a}\frac{1}{x_A \eta_T}
No, the lowercase and uppercase are the same. Merely a typo.
Wouldn't there be a natural logarithm in the answer?
\frac{d}{dn_{A}} \frac{RT ln(\frac{n_{A}}{n_{T}})}{\frac{n_{A}}{n_{T}}}
= RTn_{T} \frac{d}{dn_{A}}\frac{ln(\frac{n_{A}}{n_{T}})}{n_{A}}
= RTn_{T} \frac{d}{dn_{A}}[ln(\frac{n_{A}}{n_{T}})n^{-1}_{A} ]
= RTn_{T} [\frac{n_{T}}{n_{A}}*n^{-1}_{A} + ln(\frac{n_{A}}{n_{T}})*n^{-2}_{A}]
= RTn_{T} (\frac{n_{T}+ln(x_{A})}{n_{A}^{2}})
This is the same answer I have in the original post, with variable moved around.
Yes, if x_a = x_A
and I get:
= R T n_{T} [ \frac{1}{n_A} * n^{-1}_A + ln( \frac{n_A}{n_T} )*(- n^{-2}_{A}) ]
Stephen Tashi said:
Yes, if x_a = x_A
and I get:
My question is about a differential equation, not about the derivative of the function. I just gave the information to aid in answering my question over the differential equation, since I don't know where to start.
nBB = -nAA
It's actually very hard to say what the following symbolic manipulations do in a rigorous manner, but what your are expected to do is take an antiderivative of both sides.
x dx = - y dy
\int x dx = - \int y dy
\frac{x^2}{2} + C_1 = -\frac{y^2}{2} + C_2
x^2 + y^2 = 2(C_2 - C_1) = C where C is an arbitrary constant.
The equation you are asking about is called the Gibbs Duhem equation. If you divide both sides of the equation by nT, you get:
x_Bd\mu_B=-x_Ad\mu_A
For a binary system like the one you are looking at, xB=1-xA
So, \frac{d\mu_B}{d\mu_A}=-\frac{x_A}{(1-x_A)}
Is that what you were looking for?
Chet
Chet
I'm not actually sure what I'm looking for. I asked my professor what form he wanted our answer in and he said he can't tell me, I suppose it gives the answer away.
From my understanding, a differential equation is one where the left hand side is the derivative of a variable that is on the right side (i.e. y' = cy in the simplest form). But I haven't taken differential equations so my limited knowledge is only what was covered in calculus. In other words, I was trying to solve the differential you wrote above by somehow plugging in the previously solved for chemical potential of A. But if what your provided above is a differential equation in proper form, I suppose it will work. :P
  • · Replies 65 ·
