How Can You Simplify These Challenging Integrals?
  • Thread starter Thread starter noname1
    Couple Integrals
11 replies · 3K views
noname1
Evaluate and simpfly each integral, specify u and du
∫ e^(x/3)
∫ 6 / sqrt(9x²-5)
∫ cosh(x) / sinh(x)
∫ 4x²cos(2x)
∫ (x³+4x) / (x²-4)
∫ (2^ln(x²)) / (x) from [1,2] and for this one i need to give a simplified symbolic(non decimal) answer
on the first one, its simple and its confusing cause cause of the (x/3), should it be the same thing?
Second i choose 9X²-5 as u, so du = 18x dx
so 6∫u^-2 making it 3x³-5x + C
Third, i choose u as sinh(x) making du = cosh(x) so the answer is log|sinh(x)|
Fourth is it possible to use the tabular method?
I got 4x²-2sin(2x)-8x-4cos(2x)+8sin(2x)+c
Fifth i can use the du/sqrt(u²-a²) = ln(u+sqrt(u²-a²) +C
ln(x+sqrtx²-2²) + C
the sixth one i am confused was wondering if someone could indicate what i should use for u and help me through it
And in addition verify if the others i did are correct
Thanks in advance
Hi noname1! :smile:
(try using the X2 tag just above the Reply box :wink:)
∫ e^(x/3)
The question asks you to specify u and du.
If you mean is u = x/3, the answer is yes. :smile:
∫ 6 / sqrt(9x²-5)
No, that u would be for ∫ 6x / sqrt(9x²-5) dx.
Your u needs to be a trig expression. :wink:
∫ cosh(x) / sinh(x)
ok.
∫ 4x²cos(2x)
Try integration by parts.
∫ (x³+4x) / (x²-4)
ln(x+sqrtx²-2²) + C
uhh? :confused: the question says simplify the integral (if necessary, which it is here) … do that first.
Again, simplify it first.
could you explain better on the simplifying part?
and on the first one i am getting (1/3)e^(x/3) but www.wolframalpha.com saying its 3e^(x/3)
i choose u as (x/3) making du/3 = dx
(1/3)∫ e^u = (1/3)e^(x/3)
aint i correct?
(please use the X2 tag just above the Reply box :wink:)
No, u = x/3, du = dx/3.
(x³+4x) / (x²-4) is a fraction … simplify it.
2ln(x²) can also be simplified.
i am having problems with the ∫ 4x²cos(2x)
u*v-∫ v*du
u = x² v = 1/2sin(2x)
du = 2x*dx dv = cos(2x)4x²*1/2sin(2x) - 4∫1/2sin(2x)*2x dx
2x²sin(2x)-4∫sin(2x)*2x
u = x v = cos(2x)
du = dx dv = sin(2x)
2x²sin(2x)-4∫sin(2x)*2x +2xcos(2x) - 4∫cos(2x)
am i doing this correctly?
u*v-∫ v*du
ok so far :smile:
(but you would have found it a lot easier, and you'd be less likely to make mistakes, if you'd chosen u = 2x², v = 2cos(2x) …
then ∫ 4x²cos(2x) dx = [2x²*sin(2x)] - ∫ 4x*sin(2x) dx :wink:)
u = x v = cos(2x)
4(x²*1/2sin(2x) - 1/2∫sin(2x)*2xdx) -2x*cos(2x) - ∫cos(2x)
Sorry, this is just too confusing to read. :redface:
Try again, with brackets and using v = minus 2sin(2x) :smile:
never mind i figured it out... by simplifying do you mean long division?
∫ (x³+4x) / (x²-4)
i don't remember much how you do but its something like this correct?
x²-4 | x³+4x
-x³+4x
+8x
Giving a result of x-8x? or should i factor out the x first from the equation
You're less likely to make mistakes if you write it out like this …
(x³+4x)/(x²-4) = ((x³-4x)+8x)/(x²-4) = x + 8x/(x²-4) :wink:
got that one too, now i just don't know how i can simplify the last one
Hint: what is eln(x²) ? :smile:
hmmm, i am lost, i have no clue, can you give me the trig expression for the second one, i am just having problems on those 2.And thanks for always trying to help me
noname1 said:
hmmm, i am lost, i have no clue …
(Are you serious?)
How is ln defined?
