How Can You Solve a Differential Equation Involving Exponential Drag Force?
  • Thread starter Thread starter MichaelTam
    Force Velocity
41 replies · 6K views
MichaelTam
MIT pretest.
𝐅⃗=−𝑏𝑒^(𝑐𝑣)𝐢̂ , find v(t), by using differential equation of F=ma
There ‘s an equation, I think it should like a “drag factor” because the -(b) now has a negative symbol, which means it should be affecting the particle going parallel of the x-axis to the right, I suppose F=ma need to be apply into this equation, but before this, I need to get it into a differential equation first, but I don’t know how to isolate the exponential element, what I know is to give natural log to them , but the next step I don’t know how to do.
A particle of mass 𝑚 moving parallel to the x-axis is acted on by a velocity dependent force directed against its motion. The force is given by:
𝐅⃗=−𝑏𝑒^(𝑐𝑣)𝐢̂
where 𝑏 is a positive constant (units N), 𝑐 ia also a positive constant (units s·m−1), and 𝑣 is the speed, the magnitude of the particle's velocity (units m·s−1).
If at 𝑡=0, the particle is moving with speed 𝑣0. Find the speed 𝑣(𝑡) as a function of time 𝑡. Express your answer in terms of some or all of the following: 𝑏, 𝑚, 𝑡, 𝑐, and v_0 for 𝑣0. Use ln() for the natural logarithm function and e^() for the exponential function if needed.
This problem I can’t reach the solution have two main reason, the first is , I get too few knowledge of exponential equation (mathematical problem) and I still feel confuse about the equation of how to derive it with an exponential element in the equation in order to get the differential equation and substitute the v(t).
I am still finding the way to get the differential equation from 𝐅⃗=−𝑏𝑒^(𝑐𝑣)𝐢̂.
And what is the unit of c (s*m^-1)?(meaning)?And I know F is the only force that acting on the particle that slowing down its motion.
Can you explain this problem to me, because I am not sure the v is the F or the F is add to the v?Is it the v is the −𝑏𝑒^(𝑐𝑣)𝐢̂ according to the diagram?
My understanding to this problem is , the particle is moving in a constant velocity, but at ##v_0## a force is applied to slow down the particle, and the force is name as F
which is −𝑏𝑒^(𝑐𝑣)𝐢̂, and you need to find v(t), I am not really sure the problem is asking in this way?
And if my understanding to this problem is correct ,the F=ma the total force acting on the particle should be ##F=v{t} - b e^{ c v{t}}##?in the v{t} situation.
And the ##v_0## situation should be F=##v{0} - b e^{c v{0}}##
so it should be F=-b?
Start with Newton's second law and write the acceleration as the derivative of the velocity.
With the help of kuruman (Homework helper) I can find that:
F=ma
##F= m { dv/dt } ## where the t is the time.
##F=-b e^{c v}##
##-b e^{c v}= m { dv/dt }##
##dv={-b e^{c v}}/m## times ##dt##,but I don’t know how to remove or isolate the exponential, can you teach me to do?because the In() will move to the ##dv/dt ## if I remove the exponential.
I got ## c v = In{ m dv/{-b dt}}##
I cannot find how to type in the natural log?
You have ##-b e^{c v}= m { dv/dt }.## You need to separate variables. What algebraic steps do you need to take to have things with ##v## only on one side and things with ##t## only on the other side? Hint: To get rid of something on one side, divide both sides by that something. What could that be?
haruspex said:
Duplicate of https://www.physicsforums.com/threads/velocity-dependent-force.992948/#post-6385373
I have moved the relevant posts from the other thread to this one. The other thread is now closed.
I got ##dv= \frac {-be^{cv}} m dt##
but I don’t know how to put the ##dv## and ##v## together because there have exponential in it, can you teach me how to get ##dv +v=...##
because I need to isolate the v from the exponential, then I can do the integration effectively.I am worrying about after I integrate it, I can’t separate the v(t) and v(0) into two same variable group e.g (v(t)+v(t)).
That's not what was meant by 'putting them together'
Just rearrange the equation so that all references to v are on one side and all references to t are on the other.
You do need to know how to integrate ##\int e^x.dx##
It is the dv is respond to the c(v) or it should be a variable refer to my picture?
If my understanding is correct, it should be
If the constant k1 and k2 are not need to add on the equation(because of the t=0), the answer is at the upper part without the k.However, there are still lot of step that I am confused.
Hi can anyone help me please?Can anyone told me where I am wrong?
You certainly don’t need two constants, and substituting t=0 shows the constant is zero.
so I can ignore all constant k result in the integration?
but constant of the integration of v(t) will not equal to zero.
If my understanding to this question is correct,
I got the answer of :
##e^{-c v_0} - e^{-c v_t}=\frac {-b c t} m##
And I got:
##\frac {ln{\frac {b c t} m + e^{-c v_0}}} c##
If my understanding is correct, it should be View attachment 268502
I think you have a sign error that crept in near the end.
You had ##e^{-cv_0}-e^{-cv}=-\frac{bct}m##. Take it from there again.
I reply #17 here
And I got:
v(t)=##\frac {ln{(\frac {b c t} m + e^{-c v_0}})} c##
MichaelTam said:
I reply #17 here
And I got:
As I have explained to you twice now, you do not need a constant of integration if you use the range bounds on both sides. Look what happens if we include a constant and plug in t=0:
##e^{-c v_0} - e^{-c v_t}=\frac {-b c t} m+k##
##e^{-c v_0} - e^{-c v_0}=0+k##
##0=k##
MichaelTam said:
#21 ’s result?
Post #21 was just to show you that you do not need a constant of integration because you used the form ##\int _0^t ... = \int _{v(0)}^{v(t) } ...##.
Your equations in post #19 are correct.
So my equation in post 19 is correct, my answer also correct?
So, using the post equation in 19, I got 2, but using the 25post ,I get 1.
Ops, I forget, only 2 is the correct way, but is it the step is wrong?
