How capacitor blocks dc current?
118 replies · 55K views
SunnyBoyNY,
Based on the sentence above I assume that reactance is just X and is completely determined by its magnitude and sign. The fact that reactance is the imaginary part of impedance is taken of by the "j" before the "X".
I don't have any trouble agreeing with the above.
Studiot,
Impedance, admittance and reactance are not inherently complex quantities.
I can show you a good book that says that immittance is not a phasor quantity, but is a complex quantity. It has to be. What else can you get when you divide a sinusoidal voltage by a sinusoidal current?
They can be specified using a real modulus and a real phase angle and the calculations performed by trigonometry. Not is single i, j or k will be seen.
Exponential representation can be easily converted into rectangular or polar form by Euler's Theorem. Anytime the angle θ is not zero, there is a reactance involved, and an implied orthogonal component to the term.
Ratch
I think the point with reactance is that you could just as well describe your position on the surface of Earth as a complex number, defining some origin as 0 and doing the x y vector as x + iy. It's an arbitrary notation for a 2D system. You could just as well use a vector. As long as the two dimensions are orthogonal (which they are in space, too), using complex notation instead of a vector works.
Pythagorean,
I don't see any relationship between reactance and a position on the round surface of the Earth. What point with reactance did you have in mind?
With a vector describing a position, at least you would not be restricted to an orthogonal coordinate system. So using one vector, would it point through the Earth from, say Greenwich, England, to a position in, say Australia?
I think that would be a solution in search of a problem.
Ratch
Ratch,
this also means that reactance is negative for capacitors and positive for inductors (e.g. -500 Ohms for a capacitor as suggested by sophiecentaur).
space itself is orthogonal in all three directions. Lots of sets of variables are (it just means they're independent of each other).
All I mean, is in circuit theory, you just use complex notation to describe two states (current and potential) in one number, a complex number. You could just as easily use a vector and assume orthogonality in your vector, which is exactly how we are able to get from cartesian to polar coordinates and back again.
Ratch said:
SunnyBoyNY,
Not everywhere, elsewhere has got it wrong too. If you don't give it a sign and a "j", then the description of the reactance is incomplete.
Ratch
Can you give us a (good) reference where jX is called reactance, then?
Of course, a sign is necessary - hence my arbitrary value of negative reactance for a capacitor.
SunnyBoyNY,
As long as '"j" gets tacked on at some point, I am happy.
Ratch
Pythagorean,
I thought you were referring to the "surface" of the Earth, not space.
What does a "state" mean? What does a transform from cartesian to polar and vice versa have to do with anything? Give a simple made up example of a "state" being expressed with one number.
Ratch
Ratch said:
Pythagorean,
You can describe the surface of the Earth in spatial coordinates much like you describe the state of the elements of a circuit in "I-V space". Pick any coordinate system, xyz or phi/theta/r. All eigenbases are still orthogonal.
Ratch
Cartesian to polar coordinate transform is only valid in orthogonal systems. It applies to circuits as well as space
A state is the minimum set of variables needed to describe your system. For instance, a particle has position and velocity in it's state vector, [x,p]. A complex number is a single number, but can also represent two numbers if you think of it as a vector instead. In fact, j (or i) is just an orthogonal transform operator.
sophiecentaur,
All my reference material uses the notation Xc or Xl. But I think we are in agreement that there are two kinds of reactance, and these have to designated as reactance as opposed to resistance, and the polarity has to be shown.
Ratch
Pythagorean,
How is this going to help anyone do circuit analysis, especially figuring out whether a capacitor blocks DC current?
Ratch
Ratch said:
Pythagorean,How is this going to help anyone do circuit analysis, especially figuring out whether a capacitor blocks DC current?
Ratch
I'm not sure why you suddenly bring up pedagogy. My posting is in response to this:
Reactance of a coil or capacitor is a complex quantity, and it needs its "j".
Perhaps this is the pedagogical benefit, though; that if you use vectors instead of complex values, you won't get confused into thinking real measurable values are complex. This is probably only relevant to a science/math student though. If you're purpose is only electrical engineering, it's unlikely you'll see complex numbers in any other context, so it's probably never an issue.
Pythagorean,
I did not think an Earth coordinate system had any relevance to circuit analysis.
I believe the energy stored in the electric field of a capacitor or the magnetic field of an inductor is every bit as "real" as the energy dissipated in a resistor. Yet that reactive energy is designated as "complex" in a sinusoidal circuit.
Ratch
To my understanding the two approaches are (and ought to be) equivalent in the end.
In the big picture we could:
1) Use the usual circuit model, set up differential equations, do a nightmarish trigonometry (or transform to vectors and then do complex algebra to get the result.
2) Immediately switch to the impedance-based circuit model and do complex algebra to get the final result.
Bts. measurable values can be and are complex with respect one to another. E.g. power factor measurement. In that case we of course need multiple measurements.
Complex numbers are used throughout the EE field. Non-linear systems analysis, adaptive filtering, etc. While your vector-based example is interesting, it has little in common with the actual problem.
You seem to have some difficulty with terminology.
We distinguish three distinct types of numbers (there are others but they are irrelevant in this context)
Real numbers,
imaginary numbers which can be expressed as the product of a real number and j
complex numbers which canbe expressed as the sum of a real number and and an imaginary number.
Each have their own special properties.
In particular only real numbers can be positive or negative.
So one of the above quotes is false.
A reactance is a real number, usually given the sign X.
This may be combined with j into an imaginary number and added to or subtracted from a real resistance to achieve a complex impedance.
You get exactly what I wrote in post #90 a real modulus and a real phase angle.
So what?
I can convert or transform 3 into 6 by doubling.
Again so what?
Of course all valid methods must produce the same answer from the same data.
Your posts seem to imply that there only method available is that of complex analysis, which is simply not the case.
Studiot,
How so?
Due to its conformal similarity, multiplying by "j" gives correct answers. But "j" is really a rotational operator, not a algebraic term. For instance, 4j does not mean j+j+j+j. It really means rotate 4 by 90° CCW. The term "imaginary" has been applied to them, but they are every bit as real as the numbers along the reference line. They instead should be called something like "orthogonal numbers".
In particular only real numbers can be positive or negative. So one of the above quotes is false.
Not so. For instance, -4j means rotate (-4) 90° CCW or -4j = -j4 means rotate (4) 90° CW.
As long as it gets rotated in the right direction, everything will be OK.
Certainly.
Things equal to the same thing are equal to each other.
So what?
Again so what?
You have to ask that question to whom I was replying.
I never said anything about uniqueness or exclusivity.
Ratch
That they are equivalent is the point.
i.e., the point is that they are not intrinsically complex, they are a only convenient way of orthogonal vector handling. For instance in quantum mechanics, the Hilbert Space is actually a complex space and observables are actually complex operators. When you compute the expectation value, it resolves to a real number.
Ratch said:
Pythagorean,
Ratch
It's not actually complex though (no more than in spatial coordinates that Earth is in). The maths of complex numbers is just exploited here for convenience, that's the point. Quantum mechanics, on the other hand, really uses a complex Hilbert Space and complex operators for observables.
Pythagorean,
Whatever.
Ratch
So is (3+2.5j) positive or negative?
Studiot,
A duplex number like that has no positive or negative direction. You can only determine the positivity or negativity of its real and orthogonal components.
Ratch
Exactly.
And what of the current complexor?
Oh and duplex means bidirectional
Studiot,
Exactly.
Exactly what?
The current complex order? Please elucidate.
It also means twofold or double, as in a duplex apartment, as in the number you asked about.
Ratch
https://www.physicsforums.com/showthread.php?t=6065. Read the 5th post. I don't know why people say the current passes, it's weird!
samieee said:
hello
Capacitors are widely used in electronic circuits to block the flow of direct current while allowing alternating current to pass,how it does the job?
samieee
My definition of "J" is quite simple in my view.
J= 1<90 degrees. A vector with a magnitude of 1 pointing straight up at 90 degrees.
We all know that J*J=-1. That's because 1<90 degrees X 1<90 degrees = 1<180 degrees...also known as -1.
When I see this number: (3+2.5j)
I actually see 3<0 +(2.5*1<90) or simply 3<0 + 2.5<90.
If you think of J in these terms, I think it simplyfies things quite a bit.
I think you need to be careful about simply saying that "j = 90degrees".
It happens that you can draw a vector version (phasor) of a time varying sinusoid and that the j operator can be represented by an angle in this limited geometrical way. It's the same with Argand diagrams. But 'j' exists outside of geometry and the forms that it's commonly represented by.
I agree for some of the "super brains" of this forum. But for normal people, especially people trying to grasp "J"...my definition should take them a long way.
If you are implying that reference point of voltage isn't always zero...then sure, the "J" will be 90degrees off the reference point.
To this point in time, I have never been asked a question where my definition wouldn't satisfy the answer. But I certainly agree with your point.
By the way...who is this "Argand" fellow?
And to the point of this thread, I've never been a big physics guy when it comes to electricity...(explaining the charged plates and all that).
But I just follow the math.
Current flows thru a cap according to this C*(dv/(dt))=i(t)
In other words...no change in voltage...no current flow. (this supports caps blocking DC)
It's impedance also supports this : 0(R) + 1/(jwc) When w=0, impedance becomes infinite (caps block DC)
Actually, it's 0(R) + J*(-1/wc) Same thing...proper form for impedance I suppose.
In opposite similar fashion, L*di/dt=vt and Jwl define the "shorts" of an inductor in DC.
The 1/jwc and jwl will not be true in transients...only steady state. The other two definitions should always hold true.
I came across Mr. Argand long before phasors and calculus. Look him up. He's responsible for the Complex Plane and solutions of algebraic equations etc.. wiki rules.
