How could we calculate the limit?
  • Topic:
  • Thread starter Thread starter evinda
    Limit
10 replies · 3K views · last reply
evinda
MHB
Hello! (Wave)Let the (linear) differential equation $y'+ay=b(x)$ where $a>0, b$ continuous on $[0,+\infty)$ and $\lim_{x \to +\infty} b(x)=l \in \mathbb{R}$.
Show that each solution of the differential equation goes to $\frac{l}{a}$ while $x \to +\infty$,
i.e. if $\phi$ is any solution of the differential equation, show that $\lim_{x \to +\infty} \phi(x)=\frac{l}{a}$.
That's what I have tried:
The solution of the differential equation will be of the form:
$\phi(x)=ce^{-ax}+e^{-ax} \int_0^x e^{at}b(t) dt$
$\lim_{x \to +\infty} c e^{-ax}=0$
So, $\lim_{x \to +\infty} \phi(x)=\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at}b(t)dt$How can we calculate the limit $\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at}b(t)dt$ ? (Thinking)
The problem is easily solved using the Laplace Transform... in term of the s variable the solution is...
$\displaystyle Y(s) = \frac{B(s) - y(0)}{s + a}\ (1)$
... and applying the final value theorem is...
$\displaystyle \lim_{s \rightarrow 0} s\ B(s) = l\ (2)$
$\displaystyle \lim_{ x \rightarrow \infty} y(x) = \lim_{s \rightarrow 0} \frac{s\ [B(s) - y(0)]}{ s + a}\ (3)$
... so that is...
$\displaystyle \lim_{ x \rightarrow \infty} y(x) = \frac{l}{a}\ (4)$
Kind regards
$\chi$ $\sigma$
Hi evinda,
First consider $$l\neq 0.$$ Note that this implies
$$\lim_{x\rightarrow\infty}\int_{0}^{x}e^{at}b(t)dt$$
diverges (to $$\pm\infty,$$ depending on the sign of $$l$$). Hence, we can compute the limit for $$l\neq 0$$ using L'Hopital's rule and the Fundamental Theorem of Calculus.Next consider $$l=0.$$ Note that we have the inequality
$$\left|\int_{0}^{x}e^{at}b(t)dt \right|\leq \int_{0}^{x}e^{at}|b(t)|dt\qquad\forall x$$
Now, either the integral on the right either converges to a number $$M$$ that is finite or it diverges to $$+\infty$$ as $$x\rightarrow\infty.$$ If the integral converges as $$x\rightarrow\infty$$, then the above inequality shows that
$$\lim_{x\rightarrow\infty}e^{-ax}\int_{0}^{x}e^{at}b(t)dt=0,$$
as desired. If the integral
$$\int_{0}^{x}e^{at}|b(t)|dt$$
diverges as $$x\rightarrow\infty$$, then we can once again use L'Hopital's rule and the Fundamental Theorem of Calculus to get that the limit is zero. Let me know if anything is unclear/not quite right.
GJA said:
Hi evinda,
How do we deduce that $$\lim_{x\rightarrow\infty}\int_{0}^{x}e^{at}b(t)dt$$ diverges to $$\pm\infty$$ ? (Thinking)
Suppose $$l>0.$$ Since $$\lim_{x\rightarrow\infty}b(x)=l,$$ there is $$N>0$$ such that
$$\frac{l}{2}<b(x)\qquad\forall x\geq N$$
It then follows that
$$\infty = \frac{l}{2}\int_{N}^{\infty}e^{at}dt\leq \int_{N}^{\infty}e^{at}b(t)dt$$
I would try writing the proof for $$l<0$$ using the above as a guide. Let me know if anything is unclear/not quite right.
GJA said:
If the integral
If $$\int_{0}^{x}e^{at}|b(t)|dt$$ diverges, we cannot deduce that $\int_0^x e^{at} b(t) dt$ diverges, or can we? (Thinking)
You're 100% correct, we cannot conclude $\int_0^x e^{at} b(t) dt$ diverges as well - this was not part of the claim in the previous posts. Fortunately, we don't need to conclude this for the method outlined earlier.
In assuming $\int_{0}^{x}e^{at}|b(t)|dt$ diverges as $x\rightarrow\infty$, we can calculate the limit you want in your original post (using $\int_{0}^{x}e^{at}|b(t)|dt$ instead of $\int_{0}^{x}e^{at}b(t)dt$) via the Fundamental Theorem of Calculus and L'Hopital's Rule. If you haven't done this computation yet, give it a shot and see what you get. Then look at the inequality again. As before, I'm certain you can do this, so I am doing my best to avoid writing out all the details. Let me know, though, if you get stuck and I will help some more. Let me know if anything is unclear/not quite right.
Then it will be like that:
$$\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at} |b(t)| dt= \lim_{x \to +\infty} \frac{\int_0^x e^{at} |b(t)| dt}{e^{ax}}= \lim_{x \to +\infty} \frac{e^{ax} |b(x)|}{a e^{ax}} dt \to \frac{|l|}{a}$$
Right?
However, having found this limit can we say something about the limit $\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at} b(t) dt$? :confused:From the inequality don't we get that $-\frac{|l|}{a} \leq \lim_{x \to +\infty} e^{-ax} \int_0^x e^{at} b(t) dt \leq \frac{|l|}{a}$?
But this doen't help, or does it?
We need to recall what $l$ was in this case to finish the problem...
You mean that we have to use the fact that $\lim_{x \to +\infty} b(x)=l$? How does this help? (Thinking)
We knew specifically what $l$ was in the context of the argument you're quoting. Take a look at my previous post and you'll find the answer.
