How dense would something have to be to stop a bullet?
  • Context: Undergrad
  • Thread starter Thread starter samsanof
    Bullet
To stop a bullet traveling at 680 mph, the material must effectively expend the bullet's kinetic energy and absorb its momentum. High-density materials, such as a bale of cotton or a pile of dirt, can achieve this by spreading the impact load. The thickness of the material plays a crucial role; for instance, a 3-inch thick object requires a specific density to decelerate the bullet to a safe speed. The discussion emphasizes that air, while not compressed, can also slow a bullet over distance, but the effectiveness varies based on the bullet's profile and weight.
  • Understanding of kinetic energy and momentum conservation
  • Familiarity with bullet dynamics and material properties
  • Knowledge of basic physics equations, particularly SUVAT equations
  • Awareness of the effects of air resistance on projectile motion
  • Research the properties of high-density materials for ballistic protection
  • Learn about the physics of bullet impact and energy transfer
  • Explore the effects of air density and resistance on projectile trajectories
  • Investigate the design and function of various bullet types and their energy focus
Physicists, engineers, material scientists, and anyone interested in ballistics and projectile dynamics.
samsanof
Let's say that an object is 3 inches thick, how dense would it have to be to stop a bullet traveling 680 mp/h?
How big is the bullet? What shape is it? Does the material have a grainy structure or a homogenous gelatin structure?
kevlar isn't particularly dense, and it will easily stop a bullet. Why do you think density is a good indicator of a material's ability to stop a bullet?
Really,what i mean is how compressed would air have to be to stop a bullet?
that would be pretty cool. uh... If you know the range of a weapon, then you could work out the mass of air it traveled through. And then you can calculate the equivalent density of air which would give the same mass over a different volume.
But this would probably not work very well, since the air resistance forces are going to be non-linear for sure. Maybe assuming a force which goes as velocity squared would be better.
Not compressed at all. Our atmosphere can stop a bullet, it just takes a while. You need more information to answer this kind of thing. Do you want to stop it in a mile? In an inch? In a nanometer?
High density material employs conservation of energy and conservation of momentum to spread the impact load. The bullet fragments becomes part of the high density material.
A bullet delivers a high kinetic energy to a small area on the target over a very short period of time. To stop a bullet you must quickly convert that KE to heat, and / or spread the material over a much greater area. Some bullets are designed to focus their energy. Although they will be vaporised on impact there will still be a significant KE in that vapour. The vapour may be toxic.
He kinda was...
Ahh, my bad.
Stopping a bullet requires two things:
1. The energy of the bullet must be expended
2. The momentum of the bullet must be absorbed
A bale of cotton will do both. So will a pile of dirt.
The bullet will decelerate but never quite stop. The profile and weight of the bullet will make a big difference. You must redefine “stop” and provide some idea of the distance that is available to decelerate the bullet to a “safe” speed.
If it's of interest you could estimate the acceleration the bullet must undertake in order to stop in 3 inches. If we assume constant acceleration (which might not be a valid assumption) then we can use SUVAT equation...
V2= U2 + 2as
where
V = final velocity (eg 0)
U = initial velocity (304 meters/sec)
s = distance (eg 3 inches = 0.075 meters)
a = acceleration.
Rearranging the equation gives
a= (V2 - U2)/2s
a = -3042/0.150
= -62,000 ms-2
Roughly 6200g
I suspect a bullet would pass through 75mm of liquid nitrogen (at atmospheric pressure but that's not quite what you are asking).
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 20 ·
