How do charge gradients form inside clouds?
  • Context: Undergrad
  • Thread starter Thread starter Edison Bias
    Charge Cloud
37 replies · 7K views
Edison Bias
Hi!
It has been explained to me in another thread of mine that there actually can be lightning/thunder within a cloud.
My question now is how there can be such high charge gradients within a cloud that this can happen and of what types of ions and electrons there is and how they have emerged.
Because it's for sure not gravity, or?
As the amateur I am I will try a explanation of my own: a cloud consist of water vapor, this vapor has then become ionized by photons from the sun but if hydrogen are free ions and oxygen free ions, there should be a "big bang", right? And this still not explains the obvious gradients in space.
Edison
Things to think about: real life is messy...
You can have molecular ions, and objects like dust and water droplets can become charged.
Photoionization (sunlight) is not the only way that objects can become charged in Nature.
Objects can become charged by friction or interaction with ions carried in the air: ie by wind.
Similarly, wind can separate out charges in a region just by blowing through it, and different clouds may carry different potentials depending on their histories.
It may be that the potential difference is between a region carrying a large net negative charge and another region carrying a smaller net negative charge, with a static discharge (lighting) occurring as these regions approach.
No simple answers here, then :)
Interesting.
The only way I could think of with my limited knowledge.
Friction brings me back to how a balloon may be charged by rubbing a plastic stick on it, it then attaches to ones hair :)
Interesting.
This approach of thinking was educational, a potential difference can then consist between two regions of only electrons but with different number of electrons, right? But why not? Potential is defined by number of charge and here we only have a difference in number of charge. At the same time, why and how is there a difference in charges? As I have read the above one answer may be the wind and when the wind slows down, these regions approaches with lighting as the result.
But getting back to what you have said, ionization by sunlight is not the only way objects can become charged, friction is also important. But I still don't see how there can be so much free charges (weather they are molecules or electrons). Maybe two water molecules rubbing against each other can strip electrons so that there are water molecules of positive charge along with electrons of negative charge just by, as you have told me, friction? And wind makes these charges move away or toward each other which finally, when they are close, makes lightning? It's hard to see though.
Thanks Simon for your answer, it educated me!
Edison
yes, one region is just more positive than the other
remember it's primarily the movement of electrons and positive ions ... electrons are being stripped off atoms resulting in charge separation
not quite see previous comment and the following ones I make
yes ... consider we are talking about zillions ( uncountable numbers) of atoms being stripped of electrons
you commented on the rubbing of a balloon experiment not really big sparks being formed
take that a step further, when you rub you feet across a carpet and go to touch a doorknob etc you can produce a 5mm spark ~ 10,000 - 50,000 Volts
another step further, a Van de Graff generator, a major electron stripping operation. a few million volts and much larger sparks
now to a thunder storm cell say 20km wide and 12,000 metres high (15 miles and ~ 38,000 ft) more electrons being stripped from atoms than you could ever imagine by the friction of water droplets, ice crystals and full sized hail stones all being carried by huge updraughts within the storm cell
10's to 100's of millions of volts and huge charge build ups resulting in 10's of 1000's of amps in a single lightning bolt.
no, not quite the way you stated it
there is that charge separation with in the cloud(s), by the process I described, producing the inter and intra cloud discharges
there is also a buildup of separation of charge between the ground and the base of the clouds resulting in huge potential differences
When that potential difference ... the value of the electric field ... that is formed between the cloud base and the ground builds and finally reaches the breakdown voltage of the air gap insulation, a lightning charge will occur
Dave
Thank you Dave very much for trying to explain this to me, yet I am mainly interested in lightning within a cloud and I still not really se it happening. Friction seem more important than I ever could have thought. Nice example with the walking on a carpet and touching a handle, gave me a clue of what it's all about. But charge separation within a cloud, why and how? If two water droplets, ice chrystals or full sized hail stones are rubbed together, why should the ions and the electrons get separated? Because they need to get separated, at least for a while, so that a high potential difference can be built up, right? Otherwise they just separate and recombine, I think. So somehow these electrons and ions get separated over a considerable time and then, suddenly, they crash into each other (breakdown voltage). Because even if there are "zillions" of atoms being stripped of electrons, they need to reside somewhere for a huge potential difference to occur. If the atomes are stripped of electrons all the time, the may also recombine all the time. There thus seems to be some kind of accumulation of charge which then discharges at some convenient opportunity, which is not fully defined.
Edison
it's all in the response I gave ... here it is again
no
as the electrons are stripped from atoms that is a charge separation. The positive ions ( atoms with less than their usual # of electrons) get moved away from the negative charges ... this results in an electric potential (and electric field) building up over a distance ( the gap between them) as with the cloud to ground strikes.
when the electric field exceeds the breakdown voltage of the gap, a lightning discharge occurs. There is no difference to this occurring be it with /between areas of the cloud and between the cloud and ground.Dave
here's a few pictorial examples ...
http://icons-ak.wxug.com/i/severe/lightning_explainer.png
cheers
Dave
Once again I thank you Dave for trying to explain this to me. However I fail totally in understanding charge separation. Your kindly provided pictures looks nice and gives me more understanding generally but specifically, the charge separation with focus on staying separated and accumulate remains an enigma to me. Because where does the ions and electrons go? Why not just recombine? Why build up a huge potential difference and then discharge, I don't get it.
I expect no answer to this, you have put down enough time and effort into helping me, thanks.
Edison
my previous comments and the images clearly show where they go
recombine with what, they have become greatly separated over many kilometres as shown in the images ... between clouds and ground or between different regions in the clouds
I'm not sure how to be clearer ... the build up of the potential difference continues UNTIL the electric field reaches the breakdown voltage for that particular sized gap. Then the discharge occurs causing a recombination of the + and - charges and then the process repeats over and over until the storm dies out.
The charge separation can only occur when there is good updraught within the storm cell. As the updraught strength diminishes, so does the charge separation
Dave
I think this is the explanation I was looking for. Because how can charges of equal sign otherwise accumulate? It is even hard to understand how rubbing your feet on a carpet can strip and accumulate electrons within your body and then just discharge when you touch a doorknob of metal which even only may be sitting in a wooden door, that is the electric discharge does not even have to have a low ohmic path to the ground. It even feels like the discharge happens because the doorknob is made of metal without other considerations. As if metal itself accepts a bundle of electrons or even crave for it ;)
Edison
that's indeed how they separate
it doesn't need a path to ground ... it just needs a path to a place where the charge amount is different ... there is no grounds in the cloud are there ?
it works better with metal as it is a good conductor. remember your body can collect that charge then discharge it to another object eg remember you can charge yourself up and then zap the person standing beside you, but neither of your bodies are made of metal.
Don't go there ! it's an inanimate object, has no feelings Dave
You can often see lightning flashes within the turbulent black cloud billowing from the vent of an erupting volcano.
yup, indeed, and the process of charge separation is just the same
instead of cool wet materials in a cloud it's hot dry materials in the ash plume
D
Dave
Hi Dave!
This was a real good explanation, thanks!
By the way, I didn't really mean "crave", my english is not so good :)
Edison
Okey, Dave.
Maybe I should quit now but I am qurious, do I dare ask the question of charge accumulation? I think I understand charge separation in the aspect of stripping and friction, but I do not understand how charges with the repelling equal sign can accumulate. Let's again consider the simple situation of me walking on a carpet stripping electrons from it, why would I collect electrons at all? Is it because I'm positively charged to begin with, or? If I'm not positively charged to begin with, why would the electrons enter my body and stay there (until I touch something with a less/higher amount of electrons)? I really don't grasp this accumulation part.
Edison
I'm not sure I can answer that overly well ...
@Dale @mfb can you help please ?
My first thought would be is that the forces separating the charges is stronger than the repelling force between like charges
You are likely to be at or close to neutrally charged ( equal numbers of positive and negative charges)
some reading up of electrostatic charges may help ...
a couple on the Van de Graff generator...
https://www.boundless.com/physics/textbooks/boundless-physics-textbook/electric-charge-and-field-17/applications-of-electrostatics-138/van-de-graff-generators-496-6320/
http://www2.physics.ox.ac.uk/accelerate/resources/demonstrations/van-de-graaff-generator
a couple on general electrostatics ...
http://phun.physics.virginia.edu/topics/electrostatics.html
http://sardarsinghsir.com/XI-XII/XII-BC/I-v1.1-BC-Part-I-Electrostatics.pdfreading all those will keep you busy for a while :wink:
Dave
I think it is fairly well agreed upon that the surface of the Earth is negatively charged. It seems to me that a person standing barefoot in intimate contact with Earth is going to acquire the same charge as the Earth. Agreed?
mfb said:
The triboelectric effect (charge separation by contact) is complicated, and not always intuitive -you can get some charge separation even if you rub two identical materials.
Would you further elaborate on that ? I am quite confused how this would be possible.
The wikipedia article is full off "citation needed" and it didn't really explain why charge separation between the same materials might work.
It said, that some materials have other "chemical potentials" and so some charge is more likely to accumulate there.
However if both substances are identical then there really shoudn't be any charge separation.(When you base your assumption on only that idea)
And has there been any consensus of what the "dominant" process is in charge genertaion in a cloud ?
Speculation alert o0): I had an idea for a charge separation process.
Maybe because the droplets are often supercooled(i have no source for that) they will freeze a little upon contact with an snowflake or ball of hail, which might push out ions at different speeds causing some to be captured more in the ice than others.
To be honest I have no clue about this ...
I have read that in an article years ago, and the reason was not well understood at that time. Identical materials don't have to have completely identical properties, you still have things like temperature, strain and so on that can differ.
Negatively charges particles may attract if enough positive charges lie in between.
  • th?id=OIP.Me8fbcbeb7dce08cf5ff6dadb275012a2o0&pid=15.1&P=0&w=224&h=171.jpg
But then the positive particles are quickly going to the negative charges, neutralizing them.
The accumulation needs a different drive.
Experiments have shown a balance is achieved and an order develops.
- Ise N, Okubo T. “Ordered” distribution of electrically charged solutes in dilute solutions. Acc Chem Res. 1980;13:303.
- Ise N, Okubo T. Ordered structure in diluted solutions of highly charged polymer latices as studied by microscopy. Chem. Phys. 1983;78:536.
- http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3859271/
irrelevant ... as we weren't talking about barefooted standing on the Earth :wink:
we were talking about walking across a carpet and accumulating charge
You're right Tazerfish, it says nothing about charge separation between two identical materials. It does however say something about "chemical potentials" and while being kind of vague sounds like a good explanation for charge separation. Then it goes on with saying that two materials are charged even more if rubbed together. I think I have noticed that in practice but the reason is kind of vague.
Thinking aloud: When an electron is, by simple touch, stripped (due to differencies in chemical potentials, let's say) from the carpet and enters my body, I get negatively charged. This creates an electromagnetic force that counteracts more electron stripping, right? So why will there be more stripping of electrons if my feet rubbes the carpet harder? Finally, why do the electrons stick to me or in other words, why not recombine with the positively charged "capet"?
The carpet is sitting there awaiting each step and it now has a slightly positive charge (which attracts electrons, obs) but the electrons refuse to recombine and stays in my body until I touch something that has an enormous larger difference in charge amount and the material can even reside on an totally insulating material like a metal handle on a wooden door.
Davenn has however kindly explained the fact that there is no need for a low ohmic path (to ground) to create a spark, only difference in charge amount. But still, what makes these potentials? How can there be accumulation of charge in materials?
"I'm negative, I want to be more negative", it does not compute :)
Edison
That is correct.
You seem to assume that charges will always equalize themselves if they have somewhere to go.
That is wrong.Think about the "depletion layer" in diodes.
Because the doped semiconductors have different "chemical potentials"(which is probably the wrong term here) they will cause small layers of charges to "equalize" the "chemical potential". In other words, the system would reach equillibrium when the work done against the electric field of the charges is the same as the work done by the difference in chemical potential. So a charge would neither gain nor loose energy by going from one point to another.
That equillibrium exists when there are two small layers of charges, not when everything is neutral.
There likely are a few other examples from electrochemistry as well, but I don't know much about that.
One example would be batteries(or rather one part of them).
If you just put certain metals into water they will become solved ions(the surplus electrons remain on the metal).
Although they are now charged they have a lower potential energy. This continues until there is a certain voltage between the metal and the solution.
Then we again have equillibrium and no further charge flows.
What I found very strange is that these voltages are on the order of a few Volts. How can triboelectricity generate such huge voltages ?
Why doesn't the charging continue until some point, at which the energy difference due to the voltage is equal to the energy difference due to the chemical potential and the charging stops ?
Speculation alert 2o0): I might know the answer:
Lets look at this like a capacitor where the plates (almost) touch. Charges move from one side of the capacitor to the other, because of the difference in chemical potential.That stops when a certain pretty low voltage is reached.
Now imagine the capacitor to be pulled apart.No charge flows because when the voltage increases enough for charges to "want" to flow back the separation is already too great.The voltages you would get when the capacitor is pulled apart a large distance could be pretty big.
Subsequently, if you brought them back together the voltage would be pretty low again and charge would feel no incentive to flow back and neutralize.
Speculation end.
It is not about the difference in charge, but about the voltage.And while there is a high voltage between you and the carpet no charge will flow, mainly because the carpet is a horrible conductor and the reason i explained in the "speculation section" of this post.
You have to have a object that conducts well and is either connected to ground or has a relevant capacitance.
If you charged yourself and touched an insulated hanging metal lamp, you would get shocked and charges would flow onto the lamp until your potential was roughly equal. Nonetheless you haven't lost all your charge and some of your charge is now on the lamp.You could possibly still shock people by touching them and so could the lamp.
Ps : I have to do something about the way i write comments, because i feel like a spammero:).
PPS:When i say potential i am usually talking about erergy per charge (something very similar to voltage) and not chemical potential
it is about the difference in charge ... that is what gives rise to a voltage potential difference and electric field
What I was trying to get across is, there is no direct connection between the amount of charge difference and wether discharge will occur.
I magine you have one object that has a lot of positive charge, but is big and a small object with a small amount of positive charge.
They may have the same electrial potential and so there would not be any voltage between them, although there is a high amount of charge difference.
It also is about how the charges are distributed!You cannot predict how much charge will flow just by knowing the difference in charge.
Wouldn't you agree on that ? ;:I
I really do not know so much about physics but I find it interesting. That being said I would like to make a comment anyway:
Yes there is, from what I have been taught. The amount of charge difference gives potential difference and when this potential difference exceeds the dielectric strength of the medium, a discharge will happen. Moreover, potential is directly related to charge amount, nothing else. You probably know the definition (which I only think goes):
[tex]Work=qU=\int_{-\infty}^{r}\frac{qQ}{4\pi \epsilon r^2}dr=[-\frac{qQ}{4\pi \epsilon r}]_{-\infty}^{r}=-\frac{qQ}{4\pi \epsilon r}[/tex]
Which gives U as proportional to Q (epsilon is usually for vacuum but I think the formula is more useable if the actual medium is considered)
Here you will automatically have a potential difference, the number of positive charges will have to be exactly the same for zero potential difference, it has nothing to do with size, I think.
Following my reasoning, this is false.
This is interesting, I really don't know but I suspect it doesn't matter. However, a current (flow of charge) will flow due to the difference in amount of charge (if they not just differ in sign) and that current is depended on the potential difference as well as the resistivity between the two objects. Another aspect of this interesting thought is how there can be charge gradients (in clouds ;) ).
Finally, on the bus today I thought "why is there a discharge when I touch the metal handle and not when I touch the door? Davenn has taught me that the key reason for discharge is difference in amount of charge, okey I think I get that, but the door handle and the wooden door itself should have the same potential (amount of charge), right? Because he has also taught me that a low ohmic path to ground is of no importance. So why no discharge by touching the wooden door? Something is wrong here.
Edison
PS
Wait a minute, what does r mean in "my" formula above? Potential is inversely proportional to r (if you solve the integral) this means that two objects with the exact same amount of charge (Q) can have different potential if they are at different r and r can not be distance between Q's, right? The formula (The Electromagnetic Force) comes from distances between Q's but when it comes to potential, r has to mean something else (because a single Q has potential). So r means, what?
I guess r means height but height over what I don't know. Anyway say it's height, then if two objects has the same Q and one resides in 2r, the one at 2r will have half the potential, can this really be true? Does height at all affect voltage?
