How Do Generators Produce Alternating Current While Rotating in One Direction?
  • Context: High School
  • Thread starter Thread starter Aichuk
    Transformers
The discussion centers on the operation of generators, specifically how they produce alternating current (AC) while rotating in one direction. Participants explore the mechanics of AC generation, the role of coil motion within a magnetic field, and the implications of continuous rotation on current direction.
  • One participant expresses confusion about how a generator can produce alternating current if it rotates continuously in one direction, suggesting that it should only produce direct current (DC).
  • Another participant clarifies that the coil returns to its starting position after a full rotation, but questions remain about the nature of the current produced during this motion.
  • A different participant mentions that slip rings and brushes prevent the wires from twisting, which is a mechanism that allows for the generation of AC.
  • It is noted that as the coil rotates, the direction of the current changes due to its motion through the magnetic field, regardless of the direction of rotation.
  • One participant suggests looking up diagrams and animations of AC generators for better understanding, emphasizing the complexity of maintaining a consistent current direction if DC is desired.
Participants express differing views on how continuous rotation affects current generation, with some asserting that it should yield DC while others explain the mechanisms that allow for AC production. The discussion remains unresolved regarding the fundamental understanding of AC generation in this context.
Participants have not fully addressed the underlying assumptions about the nature of current flow and the specific mechanics of AC generation, leaving some points open for further exploration.
Aichuk
So I was just reading on generators. The basics that I've understood is that it works by inducing a current through motion of a coil on a magnetic field.
So what I didn't understand was that it produces an alternate current through full 360` rotation. In a half cycle, it induces a current in one direction and in the other half cycle it induces the current in the opposite direction. What I don't understand is that if it is rotating ONLY clockwise or anticlockwise, then why is it producing an alternating current? I thought that would happen if it rotated a half-cycle clockwise and then it rotated back to its original position by rotating a half cycle anticlockwise.
Also on a side note, doesn't the wire get twisted up if the coil keeps rotating in one direction constantly?
Edit: The title says transformers while I meant generators.
I think your question is about AC generators. Transformers don't rotate in most circumstances.
Just like any other circular motion, a coil rotated by 360 degrees is back where it started from. Rotate it agai I. The same direction and it will be back in the same place once again. You don't need to know anything about electricity to see that.
Oh right I'm so sorry, I mistakenly wrote transformers when I wanted to write generators.
Yeah but why doesn't it make an AC current. If it's rotating in one direction, then won't it just create a DC?
It would be a good idea to Google AC generator because there are dozens of diagrams and even animations to see.
First of all, the wires don't get twisted because Slip Rings and Brushes are used.
Secondly, as the coil rotates, the wires go up and down through the field, that changes the direction of the current, whichever direction the coil rotates. If you want DC out, you have to do complicated switching to keep the current in the same direction all the time. (A Commutator) Look at those diagrams - google 'Animations AC generator' and watch the pretty pictures.
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 30 ·
