How Do I Calculate Displacement for Vectors Pointing South and West?
To calculate the displacement for a journey of 110 km south and 70 km west, the Pythagorean theorem is used, yielding a displacement of approximately 130.4 km. The angle of the displacement can be determined using trigonometric functions, specifically arctan, to find the direction. It's noted that the question should clarify whether only the magnitude or both magnitude and direction are required. The discussion emphasizes the importance of clear terminology to avoid ambiguity in vector representation. Ultimately, the displacement can be expressed as 130.4 km at an angle of approximately 32.6 degrees south of west.
amazingphysics2255
A car travels 110km south and 70km west
1. Draw a vector diagram to show the journey.
2. Calculate the displacement of the car.
N/A
I have drawn a arrow pointing straight down (South) 110km and an arrow off that to the right(west) 70km.I know that the distance of the journey would be 180km. How do I go about finding the displacement?
amazingphysics2255 said:
and 70km North
to the left(east) 70km
Which is it?
Fixed.
For the displacement distance, use the Pythagorean theorem. For the displacement angle, use trig functions.
@FactChecker can you give me a link or formula?
It sounds like you have not had algebra or trigonometry yet. I recommend that you take those first. If you have already had them, you should brush up on the basic algebra and trig. They are necessary for a lot of subjects.
I know what the Pythagorean theorem is $$a^2+b^2=c^2$$I've deleted my previous post as it was unclear. I meant how do I use this in the Pythagorean theorem?
Likes FactChecker
Good. Then you should be able to calculate the magnitude of the displacement. How about the trig and the angles?
Make a drawing and label the a, b, c sides and make the appropriate calculations. You must show work on homework problems before we are allowed to help.
130.38 so 130.4 km? is this the displacement? angles and trig are not needed as far as I know.
That is the magnitude of the displacement, which may be all that is expected. If no angle is expected, you can at least say South South West. If an angle is expected, you should calculate it using arctan.
Yes, it's rather silly asking for displacement, which is by definition a vector, without specifying the format of the answer. It would be valid to answer "110km S, 70km W".
Likes FactChecker
Fixed.
Well,... currently it says
Problem Statement: A car travels 110km south and 70km west
Since 'down' refers to the paper (or the screen), one would expect 'to the right' to refer to the paper (screen) also
:oldconfused:
Well, the car makes a right turn and ends up moving left. Best avoid "right" and "left" entirely given that potential ambiguity.
I thought East was to the right: "Never Eat Shredded Wheat" is how I remember it, going clockwise from North.
They use the terms port and starboard on a boat to avoid ambiguity. They refer to left and right when facing forward.
Yeah, and then they have a brass plaque 'Starboard is to the right' nailed to the mast :biggrin:
A good sailor always has some Red Port Left.
Likes BvU
Ok. So just south 110km and west 70km. Anything else I should know?
Do you understand the point that @haruspex is making? Have you come across the ##\vec{i}, \vec j, \vec k## vectors yet?
No, I haven't come across this as of yet. And the post by haruspex that says you can write your answer as 110km S and 70km W?
I took the response from @haruspex more as a criticism of the question than as a free pass to avoid using the Pythagorean theorem.
Yeah! 130.4km . I see what he means technically your displacement would just be 110km S and 70kmW
I thought it was more like a legitimate option to give the displacement in Cartesian rather than polar coordinates. With NESW as the unit vectors.
I'm saying that it is a technically valid way of stating the displacement. It can also be specified in ##\hat i, \hat j, \hat k## vectors or as a magnitude and a direction. The question should have made it clear a) whether only the magnitude is required or b) if the vector is required, in what form.
If we rule out the options which make the answer too easy, that leaves either just the magnitude or the magnitude and direction. To be on the safe side, you should assume the last.
Likes BvU, PeroK and jbriggs444
Can someone draw a vector diagram so I can visualize this also? Note, the question doesn't ask for one to be drawn ( I added it to the question too, wasn't in the original question given to me). I have one on paper but don't know how to draw one on this site(can you?). Mine looks like a right-angled triangle. with the hypotenuse being 130.4km, the adjacent is 110km and the opposite is 70km.
That sounds correct. And show the triangle oriented correctly versus North, South, East, West. Many people just take a picture of their drawing and post it here. Make sure that is is clearly legible. I do drawings in external software and upload it to this forum.
So I could write the displacement of the car is 130.4km and 32.6degrees S of W?
"32.6degrees S of N" does not make sense to me as a direction. One way to describe a direction is as an angle clockwise from due North. That is called the bearing. What did you get for that? Do you have a drawing whose photo you can post? (You can just drag the photo to the writing area.)
I agree S of N doesn't make sense I meant S of W.
Is 36 degrees south of west more nearly due south or more nearly due west.
Is 110 km south and 70 km west more nearly due south or more nearly due west.
16K
13K
