How do I compute magnetic flux?
The discussion revolves around computing magnetic flux in the context of a circular loop rotating in a magnetic field. The original poster presents a specific scenario involving a loop with a radius of 10 cm in a magnetic field of 1 T, questioning how to compute the magnetic flux and induced emf.
  • Participants explore the definition of magnetic flux and its relation to magnetic field and area. There is a discussion about how to calculate the area considering the angle between the magnetic field and the loop's normal axis. Questions arise regarding the correct formulation of area and its dependence on the angle.
The discussion is active, with participants providing insights into the relationship between magnetic flux, area, and angle. Some guidance has been offered regarding the projection of the surface area and the formulation of the area in relation to time. However, there is no explicit consensus on the final approach to solving the problem.
Participants are navigating the complexities of the problem, including the effects of changing angles and the need to express area in a generic form. The original poster's understanding of Faraday's law is acknowledged, but the application remains under discussion.
austin007
A circular loop (with a radius of 10 cm) rotattes in a constant magnetic fiels, which has a magnitude of 1 T. At an instant when the angle between the magnetic field and the normal axis (to the plane of the loop) is equal to 10 degrees and is increasing at a rate of 20 degrees/s, what is the magnitude of the induced emf in the loop?
How do I compute magnetic flux? ( I know that farady's law can be used to find emf)
Firstly, what do you understand by "magnetic flux"?
It is the product of magnetic field, B and perpendicular surface area to B, A.
I know B which is 1 T, how do I get A especially the angle.
Consider the projection of the surface area of the loop onto the plane perpendicular to the magnetic field (sort of like the 'shadow'). (You can consider the loop in 2D - a straight line to simplify the analysis)
So is A = pi * r * r cos(10 deg + 20 deg * t) correct?
That would be the correct A (perpendicular) for any time t if the rate of increase remains constant over time. However, it would not help you solve the problem. You should formulate it in a generic fashion: A = pi * r * r cos (theta), solve for dA/dt, before substituting the relevant values into obtain the solution at that point.
At any instant the magnetic flux φ = B*A*cosθ.
So induced emf e = - dφ/dt = -(-B*A*sinθ*dθ/dt )
