How do I factor x^3-1?
  • Context: High School
  • Thread starter Thread starter candynrg
    Difference Squares
14 replies · 3K views
candynrg
How do I factor this equation
x^3-1
Mathematics news on Phys.org
Difference of cubes you mean
[tex](x - 1)(x^2 + x + 1)[/tex]
No cubes there,just squares.
[tex]\left(x^{\frac{3}{2}}\right)^{2}-1^{2}[/tex]
Daniel.
P.S.Regarding a proof for the formula Cyclovenom posted,try polynomial division.
Isn't [tex]x \times x^2 = x^3[/tex] a cube? Or is the power of 3 now a square?! :redface:
Cyclovenom's factorisation [tex](x - 1)(x^2 + x + 1)[/tex] works fine and the problem is typically the difference of two cubes. Your factorisation works fine too.
-M
It does work
[tex]a^2 - b^2 = (a+b)(a-b)[/tex]
[tex]a = x^{\frac{3}{2}}, b = 1[/tex]
[tex](x^\frac{3}{2} + 1)(x^\frac{3}{2}-1)[/tex]
Hey i was reading something on paper and was thinking in about 5 dimensions and it isn't always easy for me to come back down to one - so sorry.
I corrected the erratum a few minutes later when I begn thinking about complex numbers and the post now stands happy and correct.
The mistake i made was not treating the statement as
[tex]- 1^2[/tex] which equals [tex]-1[/tex]
but as
[tex](- 1)^2[/tex] which of course equals [tex]1[/tex]
-M
Well yes [tex]x^3[/tex] is certainly a cube, but Daniel is saying that [tex]\left(x^{\frac{3}{2}}\right)^{2}=x^3[/tex].
z-component I was making reference to
when he was talking about the difference of two cubes.
i of course was not trying to deny the fact that [tex]\left(x^{\frac{3}{2}}\right)^{2}=x^3[/tex]
-M
Ah, ok. I understand.
Read the title of the thread "difference of squares", which would imply it's asking how to factor my difference of squares as apposed to any other method. It's probabily a mistake by the author but still...
However, to get back to the question posed before dextercioby threw his monkey wrench into the machinery: x3- 1 is a sum of cubes and can be factored as x3- 1= (x-1)(x2+ x+ 1). In general xn- yn= (x-y)(xn-1+ xn-2y+ . . .+ x2yn-3+ xyn-2+ yn-1).
how is that last general form, derived ?
Polynomial division.You know that the polynomial [itex]P(x)=x^{n}-y^{n} \ ,\mbox{n=odd}[/itex] has at least one real root and it's easy to see that the root is "y".Therefore you know that the remainder of the division of the polynomial [itex]P(x)[/itex] through the monom [itex]x-y[/itex] is zero and all u have to do is compute the ratio.
Daniel.
May I add, lettng [tex]\zeta =\frac{-1+\sqrt-3}{2}[/tex], we can continue the factorization arriving at:
[tex]X^3-Y^3 = (X-Y)(X-\zeta{Y})(X-\zeta^2Y)[/tex]
Polynomial division is one way. The other is using the formula for sum of a geometric progression.
Note that the series that HallsofIvy posted is a geometric sum with first term [itex]x^{(n-1)}[/itex] and common ratio [itex]\frac{y}{x}[/itex] giving the sum (to n terms) of :
[tex]\frac{x^{n-1}({(\frac{y}{x})}^n - 1)}{\frac{y}{x} - 1}[/tex] which reduces to [tex]\frac{y^n - x^n}{y - x}[/tex]
