How do I find an exact line from a large file in fortran90
The discussion revolves around reading a specific matrix from a large file using Fortran90. Participants are exploring methods to locate a line containing the phrase "OVERLAP MATRIX - CELL N." and subsequently read the matrix data that follows this line. The context includes programming challenges related to file input/output and string comparison.
  • One participant suggests using line numbers to loop through the file until the desired line is found, but acknowledges that line numbers may vary across files.
  • Another participant proposes reading each line as a string and comparing it to the target line, indicating that this method could allow for the correct identification of the matrix.
  • There is a question about whether the target line is unique in the file, with some participants confirming that it is unique, which may simplify the search process.
  • Several participants provide code snippets and feedback on the original code, pointing out issues such as unnecessary line counting and the need for exact string matching.
  • One participant expresses difficulty in implementing the suggested solutions, indicating that their code is not functioning as expected despite following the recommendations.
Participants generally agree on the approach of reading lines as strings and searching for a match. However, there is disagreement regarding the effectiveness of the proposed solutions, as some participants report issues with their implementations.
Some limitations include potential variations in line formatting and the need for exact string matches, which may not be addressed in all provided solutions. Additionally, the discussion does not resolve the specific coding issues faced by participants.
kranthi4689
I'm new to prorgramming . I have been working with Fortran90 for my physics project and I have to read data from a file. I need to find a specific matrix and then print the said matrix onto a different file and diagonalize it. How do I read the matrix that follows a specific line from a file . My file looks like this:
OVERLAP MATRIX - CELL N. 1( 0 0 0)
1 2 3 4 5 6 ...
1 1.0000E+00
2 6.5891E-01 1.0000E+00
3 0.0000E+00 0.0000E+00 1.0000E+00
4 0.0000E+00 0.0000E+00 0.0000E+00 1.0000E+00
5 0.0000E+00 0.0000E+00 0.0000E+00 0.0000E+00 1.0000E+00
6 0.0000E+00 0.0000E+00 6.7373E-01 0.0000E+00 0.0000E+00 1.0000E+00
7 0.0000E+00 0.0000E+00 0.0000E+00 6.7373E-01 0.0000E+00 0.0000E+00 ...
Now, If the line overlap matrix -cell n is found then I need to read the matrix below it. How can I achieve this using fortran. thank you.
Technology news on Phys.org
From the looks of your data, you can use the line number at the beginning of each line (is that something you can count on?) to loop through a "do-nothing" read loop to the line you want and then start the real reading of the matrix.
No. Line number can vary from file to file. so I cannot use it.
You need to read in a line as a string, then compare with the line you are looking for. You loop over that until a match is read, then you can start reading in the matrix.
Can you assume that the line you want is unique in the file? Or at least that it is the first occurrence of that text line? You might be surprised at how often things go wrong in a file of data.
I did that using a code from stackoverflow, but it is not working,
Fortran:
program open_file
implicit none
integer ::ios
character (len =39) :: str_name
character , allocatable :: command(:)
character (len=200) :: line
integer :: n,i
str_name = 'OVERLAP MATRIX - CELL N.   1(  0  0  0)'
open(unit=10,FILE='InAs_bulk_lanl2dz.outp',iostat=ios)
if ( ios /= 0 ) stop "Error opening inputfile"
    n = 0
    do
        read(10, '(A)', iostat=ios) line
        if (ios/= 0 ) exit
    n=n+1
    end do
print*, "File contains ", n, "commands"
print*, str_name , len_trim(str_name)
    allocate(command(n))
    rewind(10)
    do i = 1, n
        read(10,'(A)') command(i)
    end do
    close(10)
    do i=1,n
    if (trim(command(i)) /= trim(str_name)) then
    print *, "target"
        else
            !print*, command(i), str_name
            print*, "not found"
    endif
enddo
ENDPROGRAM
any help.
yeah . the line is unique to the file .
Good. Then you are safe in using @DrClaude 's recommendation.
I did try that approach but for some reason, I cannot check for that string. I posted the code above. if possible could you look into it.
There are many problems with the code. This first part seems to only count the number of lines which is completely unnecessary.
You need something like
Fortran:
implicit none
integer ::ios
    do
        read(10,'(A)') line
        if (line(1:39) == str_name) exit
    end do
! continue with reading the matrix
You have to make sure that str_name matches exactly the line in the file.
Fortran:
implicit none
integer ::ios
    do
        read(10,'(A)') line
    end do
I tried your solution u
Fortran:
implicit none
integer ::ios
    do
        read(10,'(A)') line
    end do
I tried to read the line. but it is not reading it. I did exactly like you said.
Fortran:
program read_mat
implicit none
integer ::ios,i
character (len=1000) :: line
str_name='OVERLAP MATRIX - CELL N.   1(  0  0  0)'
open(unit=10,FILE='data.dat',iostat=ios)
    do
        read(10,'(A)',end=100) line
        if (line(1:39) == str_name) then
        write(*,*) "found line"
        endif
    end do
100 close(10)
end program read_mat
my file is :
1 2 3 4 5 6 7 8 9 10
1 1.0000E+00
7 0.0000E+00 0.0000E+00 0.0000E+00 6.7373E-01 0.0000E+00 0.0000E+00 1.0000E+00
8 0.0000E+00 0.0000E+00 0.0000E+00 0.0000E+00 6.7373E-01 0.0000E+00 0.0000E+00 1.0000E+00
9 3.5521E-02 1.2488E-01 -9.4002E-02 9.4002E-02 9.4002E-02 -1.7531E-01 1.7531E-01 1.7531E-01 1.0000E+00
10 1.1830E-01 2.7534E-01 -1.8038E-01 1.8038E-01 1.8038E-01 -3.1590E-01 3.1590E-01 3.1590E-01 6.8256E-01 1.0000E+00
11 6.2932E-02 9.8027E-02 -4.8573E-02 1.1828E-01 1.1828E-01 4.4339E-02 9.1732E-02 9.1732E-02 0.0000E+00 0.0000E+00
12 -6.2932E-02 -9.8027E-02 1.1828E-01 -4.8573E-02 -1.1828E-01 9.1732E-02 4.4339E-02 -9.1732E-02 0.0000E+00 0.0000E+00
13 -6.2932E-02 -9.8027E-02 1.1828E-01 -1.1828E-01 -4.8573E-02 9.1732E-02 -9.1732E-02 4.4339E-02 0.0000E+00 0.0000E+00
14 1.8034E-01 2.6410E-01 5.8440E-04 2.1454E-01 2.1454E-01 1.7823E-01 1.9997E-01 1.9997E-01 0.0000E+00 0.0000E+00
15 -1.8034E-01 -2.6410E-01 2.1454E-01 5.8440E-04 -2.1454E-01 1.9997E-01 1.7823E-01 -1.9997E-01 0.0000E+00 0.0000E+00
16 -1.8034E-01 -2.6410E-01 2.1454E-01 -2.1454E-01 5.8440E-04 1.9997E-01 -1.9997E-01 1.7823E-01 0.0000E+00 0.0000E+00
11 12 13 14 15 16
11 1.0000E+00
12 0.0000E+00 1.0000E+00
13 0.0000E+00 0.0000E+00 1.0000E+00
14 6.8765E-01 0.0000E+00 0.0000E+00 1.0000E+00
15 0.0000E+00 6.8765E-01 0.0000E+00 0.0000E+00 1.0000E+00
16 0.0000E+00 0.0000E+00 6.8765E-01 0.0000E+00 0.0000E+00 1.0000E+00
FOCK MATRIX - CELL N. 1( 0 0 0)
I see no line in your file that says
"'OVERLAP MATRIX - CELL N. 1( 0 0 0)"
but I do see
"OVERLAP MATRIX - CELL N. 1( 0 0 0)"
but I do see
Sorry, I don't understand. what is it that's missing
Your code is hard to follow due to your inconsistent indentation. I have added comment lines with numbers in your code that are tied to my further comments below your code.
Fortran:
program open_file
implicit none
integer ::ios
integer :: n,i
    n = 0        ! 1 Why are this line and the following lines indented?
    do        ! 2 The do loop is not part of the if statement, but the indentation suggests that it is.
        if (ios/= 0 ) exit
    n=n+1        ! 3 The line should be indented the same as the line above it.
    end do
    allocate(command(n))                                                  ! 4 Why is this line indented?
    rewind(10)
    do i = 1, n
    end do
    close(10)
    do i=1,n
    if (trim(command(i)) /= trim(str_name)) then             ! 5 Should be indented
    print *, "target"
        else        ! 6 Else should be aligned with the if statement it matches
            print*, "not found"
    endif
enddo
ENDPROGRAM                                                              ! 7 I'm not sure this will compile without a space between end and program
Here is how I would lay out your program to make it more readable:
Fortran:
program open_file
implicit none
integer ::ios
integer :: n,i
n = 0
do
     if (ios/= 0 ) exit
     n=n+1
end do
rewind(10)
do i = 1, n
end do
close(10)
do i=1,n
        print *, "target"
    else
       print*, "not found"
   endif
enddo
END PROGRAM open_file
Fortran:
program open_file
implicit none
integer ::ios
integer :: n,i
        if (ios/= 0 ) exit
    end do
    rewind(10)
    do i = 1, n
    end do
    close(10)
    do i=1,n
    print *, "target"
            print*, "not found"
    endif
enddo
Fortran:
program open_file
implicit none
integer ::ios
integer :: n,i
n = 0
do
     if (ios/= 0 ) exit
     n=n+1
end do
rewind(10)
do i = 1, n
end do
close(10)
do i=1,n
        print *, "target"
    else
       print*, "not found"
   endif
enddo
thank you for the quick edit, but even then the code doesn't read the said line. Can you tell me where is it I am going wrong
The formatting in these forum posts have hidden that the text being searched for has a different number of blank spaces than the line in the file. That causes the match to fail. Make sure that your copy and paste is exact.
For many things like this, I like to use small Perl programs (Python would also work) to pre-process input files so that the FORTRAN code does not have to do string searches or manipulation. Those languages (especially Perl) are very good at those tasks. The pre-processing programs can be called from the FORTRAN program in a system call or vice versa. I always use the scripting language (Perl/Python/Bash etc.) as the top level program.
  • · Replies 58 ·
