How do I find the distance between two lines passing through different points?
  • Thread starter Thread starter SteliosVas
    Lines
SteliosVas
Okay thanks everyone for taking the time to read this quesiton. Now I sort of know how to do this question but I am not entirely sure how I should approach it:
I have points A(2,1,2) B(3,2,-1) C(-1,2,4) and D(-2,1,3)
Now a line passes through points A and B and also C and D respectively. What essentially we need to find is that the line that passes through A and B is at least 1 metre apart from the line that passes through C and D
Dot Product, cross product. unit vector, shortest distance between two points*
[/B]
So in order for there to be a distance we must check if the lines are parallel or not...
After conducting a test I found that these lines are skewed.
What I am confused about is this. I have 4 sets of coordinates now I know if I do
AB = B - A = (1,1,-1)
and CD = D - C = (-1,-1,-1) I get two vector equations
Now to find the distance between two vector equations we use vector projection and the unit vector but I am not sure how I can lay that out
So you have two lines ##\vec A + \lambda(\vec B - \vec A)## and ##\vec C + \mu (\vec D - \vec C)##.
If I follow this example I need the veector product ##\vec N = \vec {AB} \times \vec {CD}## as the main step.
And note their extremely important tip: make a picture to see what you are doing !
