How do I find the necessary height for a shot tower in this problem?
In summary, ball bearings can be made by letting shperical drops of molten metal fall inside a tall tower - called a shot tower- and solidify as they fall. If a bearing needs 4.0s to solidify enough for impact, then the tower must be at least 39.2 m high. The bearing's impact velocity is 9.8 m/s.
Lida
Ball bearings can be made by leting shperical drops of molten metal fall inside a tall tower - called a shot tower- and solidify as they fall.
If a bearing needs 4.0s to solidify enough for impact, how high must the tower be?
What is the bearing's impact velocity?
I've never taken a physics course before. I have no idea how to figure out the height of the shot tower, I think I'm supposed to know from the 4 seconds that the tower is a certain height, but I'm totally clueless. If someone could even just tell me how to figure that out I'd really appreciate it.
I saw an old post with a near identical question from 2 years ago, but looking at the answer given there didn't help me figure out what to do here.
Help??
Help??
Welcome to PF Lida,
What is the acceleration of the shot?
Hootenanny said:
Welcome to PF Lida,
I dooooon't knooooow! :(
Should it be obvious from the problem? I'm so confused by this.
And thanks for the welcome. :)
No problem, I see from your initial post that this is your first physics class, do you have a class text? Have you come across kinematic (SUVAT) equations before?
Ok. I have a book called "How to Solve Physics Problems" and it uses 9.8 a lot for free falling objects, so I'm guessing that might be the acceleration of a falling object?
If that's the case, then the shot tower is 39.2 m right?
And I got that the velocity was 9.8 m/s, but I'm not so sure about that. Is it right?
Thanks!
Correct. 9.8 m/s2 is the acceleration due to gravity or the acceleration of an object in freefall.
Not quite, perhaps if you detailed you calculations we could point out where you're going wrong.
Thanks!
No, that's incorrect. Use this equation, and solve for y (height). Make sure that you plug in your known variables: a (acceleration), t (time).
[tex]y = \frac{1}{2}at^2[/tex]
With this formula I got 192.08m for the tower and 48.02m/s for my velocity. Closer?
I multiplied 9.8 by 4 in an attempt to reverse the equation for acceleration.
Now I figured 39.2 as my velocity and got 348.88 for the tower. This doesn't seem right, but I did that using the x-x0= v0t + 1/2at^2 equation. ( I'm using 192.08 for 1/2at^2)
Using 19.6 instead of 192.08, because I think that might be where I'm going wrong, I end up with 176.4.
Are either of my answers right?
How do I figure out the difference between x and x0?
I think the answer is 78.4 now...hopefully.
Correct :approve:
Finally!
Thanks! :biggrin:
Related to How do I find the necessary height for a shot tower in this problem?
1. What is the purpose of a shot tower?
A shot tower is used to create small spherical balls of lead for ammunition and other purposes.
2. How do you determine the necessary height for a shot tower?
The necessary height for a shot tower is determined by the size and weight of the shot that needs to be produced. The higher the tower, the longer the fall and the more spherical the resulting shot will be.
3. What factors influence the necessary height for a shot tower?
The factors that influence the necessary height for a shot tower include the type of shot being produced, the desired size and weight of the shot, the temperature and humidity of the surrounding environment, and the design and structure of the tower itself.
4. Can the necessary height for a shot tower be calculated?
Yes, the necessary height for a shot tower can be calculated using the specific gravity of lead, the desired size and weight of the shot, and the formula for calculating the free fall distance.
5. Are there any safety considerations when determining the necessary height for a shot tower?
Yes, safety is a crucial consideration when determining the necessary height for a shot tower. The tower must be structurally sound and built to handle the weight and impact of the falling lead. Additionally, safety measures such as protective barriers and safety equipment should be in place to protect workers and bystanders from potential hazards.
20K
  • Precalculus Mathematics Homework Help
