How Do I Find the Speed Without Friction?
  • Thread starter Thread starter max1020
    Speed
To find the speed of the toboggan at point B, use the conservation of energy principle, where the potential energy at point A is converted into kinetic energy at point B. The potential energy at A is calculated as 8820J, which equals the kinetic energy at B since friction is negligible. The kinetic energy (K.E.) can be related to speed using the formula K.E. = 0.5 * m * v^2. Rearranging this gives the speed as v = sqrt(2 * K.E. / m). Thus, applying these principles will yield the speed of the toboggan at point B.
max1020
some children go tobogganing on an icy hill. They start from rest at the top of the hill as shown in the diagram. The toboggan and children have a combined mass of 90 kg. If friction is small enough to be ignored, determine:
The speed of the toboggan at B
A is at 10m
B is at 0
C is at 3m
I only know the potential energy for A, the mass, and initial velocity
You know the potential energy for A relative to where? Relative to B?
If so, then that's enough information.
You know about conservation of energy, right? All of the potential energy of A relative to B will have been converted into kinetic energy (at point B).
I know the total mechanical energy for A which is 8820J
That is the sum of the kinetic and gravitational potential energy at point A?
If so, then that sum will have the same value at point B.
But how do I use that to find speed? Is there a formula for that
Conservation of energy: the total of potential energy and kinetic energy is constant. You know the potential energy at the top where the kinetic energy is 0. At a lower point where the potential energy is lower, the kinetic energy is the difference between the two potential energies. You can find the velocity from the kinetic energy.
Do you know a formula that relates the K.E. of an object to its velocity?
Is it
V=sqrt2k/m
max1020 said:
Is it
V=sqrt2k/m
No, not quite right...but you could make it right be adding a pair of parentheses. :wink:
  • · Replies 19 ·
