How do i generate nitrous oxide from a electrical arc?
  • Context: Undergrad
  • Thread starter Thread starter nuclear-boy
    Arc Electrical
The discussion centers on generating nitrous oxide (N2O) using a homemade high voltage power supply that produces a 20KV electrical arc. It is established that while an electrical arc can produce some N2O, it predominantly generates toxic compounds such as nitric oxide (NO), nitrogen dioxide (NO2), and ozone (O3). The method is deemed inefficient and hazardous, with a consensus that proper production methods for nitrous oxide are dangerous and not suitable for amateur experimentation.
  • Understanding of electrical arc phenomena
  • Knowledge of gas chemistry, specifically nitrogen oxides
  • Familiarity with high voltage power supply safety protocols
  • Awareness of toxic gas handling and ventilation requirements
  • Research safe methods for producing nitrous oxide in a controlled environment
  • Learn about the chemical reactions involved in electrical arcs
  • Study the properties and dangers of nitrogen oxides
  • Explore safety measures for working with high voltage equipment
Individuals interested in chemistry, electrical engineering students, safety professionals, and anyone researching the production of nitrogen oxides and their implications.
nuclear-boy
hi,
i have a home-made high voltage power supply which produces an arc of about 1 inch long maximum, which i assume is about 20KV, how can i generate nitrous oxide with this spark?
will you give me more information about what chemicals/gases are produced from an arc, and what the percentages and concentrations are, and just general information, as i cannot find any info on the net?
please help me!
thanks in advance, alf.
An electrical arc through air may produce some N2O, but it will also produce plenty of nitric oxide, nitrogen dioxide, some higher nitrogen oxides and lots of ozone. All of which are very toxic compounds, which is why you should never have an electrical arc in a non-ventilated space. Anyway, that's would be ridiculously inefficient way to produce nitrous oxide, and almost all proper methods of producing it (which I don't intend to name) are hazardous, since they usually/potentially produce other nitrogen oxides as well.
I'm not going to provide how-to details on the potentially dangerous production methods of a narcotic gas. Besides being clearly against forum rules, if you're ill-informed enough to to think an arc discharge would be a useful synthesis method, it would be extremely irresponsible.
Thank you alxm, well said. Thread is closed.
  • · Replies 21 ·
  • · Replies 73 ·
