How do I insert math to a post?
  • Thread starter Thread starter KorvusKoraks
4 replies · 1K views
KorvusKoraks
I can't see a button for that anywhere :(
So that for example in 1/2 the "/" would be a horizontal line.
There's no button. It's LaTeX. Have a look at the LaTeX Primer.
You use ##\LaTeX##, for which see the guidelines: (point 6)
(##\TeX## commercial:)
It's so easy ! just put ## or $$ around the expression to get ##LaTeX## .
So $$(aB/2)t^2 + vB(initial)*t - vA(initial)*t + xBi = 0$$ becomes $$(aB/2)t^2 + vB(initial)*t - vA(initial)*t + xBi = 0$$
Then: superscripts come with ^ and subscripts with _ and grouping goes with curly brackets {...}
You learn from other posts with a right-click on the formula and picking Show Math as ... ##\TeX## commands.
For your question: \frac {a+2} {b} gives ## \frac {a+2} {b} ## and {1-2-3\over 4-5-6} gives ##{1-2-3\over 4-5-6} ##
[edit] by the way: :welcome: ! And don't hesitate to post whatever. We are used to imperfection (we only strive for perfecetion :smile:)
[edit] perfection (unintended, but fortunate typo -- I like having it there :rolleyes: )
fresh_42 said:
It would be ##\text{##\frac{1}{2}##}## or ##\text{[itex]\frac{1}{2}[/itex]}## or ½ with the usage of the symbols you may use after clicking on ∑ in the editor window.
See also:
https://www.physicsforums.com/help/latexhelp/
http://detexify.kirelabs.org/symbols.html
https://www.sharelatex.com/learn/Spacing_in_math_mode
Thanks a lot to everyone for the info! I have used LaTeX before, I'll have to try to recall how to use it...
