How do I remove -9.9 values from a MATLAB histogram?
12 replies · 3K views · last reply
quasarLie
Hello everyone, I'm trying to make a MATLAB program which read a file.dat and then do a histogram
This what I did
Matlab:
Data2=importdata('Ma.DAT');
R1=Data2.data(:,17)
R1(R1>-9.9)
L = 0:0.1:8;
histc(R1,L)
bar(L,histc(R1,L),'histc')
xlabel('R1')
ylabel('counts')
[FONT=PT Sans, san-serif]I want to eliminate all the number = -9.9 present in my clomn (R1), How can i do that? i tried this R1(R1>-9.9) but it doesn't work :p can anyone help me please?
Thanks
Thanks
Try
R1 = R1(R1>-9.9) % Assign the new, "fixed" data back to R1
or, if you want to preserve the column indices,
R1(R1>-9.9) = NaN % These shouldn't appear in the histogram
Tnanks, the first one works, but the second one gives only value = -9.9 and Nan
Sorry, I meant R1(R1==-9.9)=NaN.
Thanks, the code doesn't give me the right x value et y value, do you have any idea why?
If you eliminate the R1 values that don't fit your criteria, but not the corresponding L values, then they won't line up.
If you have a picture or a more detailed description, that might help us understand the output you're getting.
It give me this histogram, which is not correct because i have 240 objects and B1 have value between 0 and 3.8 (by 0.1 step). and it should not be empty at the value=0.4
MATLAB histogram titled MAG1518 of B1 (x-axis, 0 to 2.5) against counts (y-axis, 0 to 40), with bars at irregular intervals, the tallest near 0.5 and 0.2, and a gap around 0.3 to 0.4.
  • Cropped toolbar strip showing a camera icon, subscript x₂ and superscript x² buttons, and a save icon, likely from a LaTeX or math editor.
  • MATLAB histogram titled MAG1518 of B1 (x-axis, 0 to 2.5) against counts (y-axis, 0 to 40), with bars at irregular intervals, the tallest near 0.5 and 0.2, and a gap around 0.3 to 0.4.
Yes, these are my data
0.70 0.10 0 0.80 0.80 1 0.80 1.2 0.60 2.50 0 0.5 0.70 0.60 0.10 0.60 0.70 0.60 0.10 0.20 0.70 3.1 0.40 0.3
0.500000000000000
0.800000000000000
0.100000000000000
0.200000000000000
1.50000000000000
0.800000000000000
1.60000000000000
0.200000000000000
0.200000000000000
0.900000000000000
0.300000000000000
0.600000000000000
0.400000000000000
0.100000000000000
1.10000000000000
0.600000000000000
0.200000000000000
0.200000000000000
0.100000000000000
0.700000000000000
1.40000000000000
1.40000000000000
1.10000000000000
0.400000000000000
0.900000000000000
0.600000000000000
1.80000000000000
0.100000000000000
0.900000000000000
1.10000000000000
0.700000000000000
0.300000000000000
0.400000000000000
2.90000000000000
0.300000000000000
0.300000000000000
0.600000000000000
1.30000000000000
0.600000000000000
1.50000000000000
0.100000000000000
0.100000000000000
0.600000000000000
1.60000000000000
0.200000000000000
1.50000000000000
0.200000000000000
0.600000000000000
0.300000000000000
1.10000000000000
0.500000000000000
0.400000000000000
0.400000000000000
0.200000000000000
0.100000000000000
0.900000000000000
0.700000000000000
0.800000000000000
0.500000000000000
0.300000000000000
0.700000000000000
0.300000000000000
0.900000000000000
0.900000000000000
0.600000000000000
0.600000000000000
2.50000000000000
0.600000000000000
0.400000000000000
0.100000000000000
0.800000000000000
2.30000000000000
0.900000000000000
0.200000000000000
0.200000000000000
0.500000000000000
7.50000000000000
1.30000000000000
0.300000000000000
0.400000000000000
1.50000000000000
0.700000000000000
0.200000000000000
0.400000000000000
0.400000000000000
0.100000000000000
0.100000000000000
0.800000000000000
3.70000000000000
3.40000000000000
0.300000000000000
0.100000000000000
0.400000000000000
0.800000000000000
0.100000000000000
0.100000000000000
0.100000000000000
0.300000000000000
0.500000000000000
1.40000000000000
0.400000000000000
0.400000000000000
0.400000000000000
0.100000000000000
1.10000000000000
0.400000000000000
0.400000000000000
0.100000000000000
0.300000000000000
0.700000000000000
0.500000000000000
The unexpected behavior comes from your use of the : operator to make your array of bin edges, in the statement:
Code:
L = 0:0.1:8;
There is a small floating point error in the bin edges that causes data points such as 0.300000000000000, which lie (almost) exactly at the edge between two bins, to be inconsistently included into one (intended) bin as opposed to the next.
To illustrate what is happening, try the following code:
Code:
a = L - 0.3;
a(4)
Soory but i really don't see how i can fix it. I tried what you said but it changes nothing iot gives the same histogram
olivermsun said:
Are you sure your data have values in the interval [0.4, 0.5)?
Code:
L = 0:0.1:8;
Code:
a = L - 0.3;
a(4)
what do you mean by between two bins, why this happens only with 0.3 and 0.7??
You are using histc() to break up the data into bins, with the border between bins at 0.0, 0.1, 0.2, ..., right?
How does it decide where to put the data point 0.300000000000000?
