How do I show something is pathwise connected?
  • Thread starter amanda_ou812
10 replies · 3K views · last reply
amanda_ou812
I need to prove that X={(x,y):a<=x<=b, c<=y<=d}
I was thinking of using proof by contradiction.
Assume that X is not pathwise connected, then for a,b in X there is no continuous function that connects the two.
I can show that then the set is disconnected but not sure where to go after that.
Am I going about it the correct way?
Thanks!
Why can't you just give the path that connects two points??
Given (x,y) and (u,v). What path can you take that connects (x,y) and (u,v)?
if I take a straight line path from the points, it would be the distance between the two, so sqrt((x-u)^2 + (y-v)^2)
I don't care about the distance. I want a function [itex][0,1]\rightarrow X[/itex]. A linear path is ok. How do you write that in function language?
i am not sure what you mean by function language but I would want f(0) = (x,y) and f(1) = (u, v)
i want to say something like
given f(0) = (x, y) and p in [0,1] then f(p) = ((y-v)/(x-u)) * p + (x, y)
but that's not correct bc i am switching between R and R^2
do i need to make a continuous function for each component?
do I do it peicewise? like f(p) = (x,y) for p=0, (u, v) for p=1 and then this other functions that I cannot figure out how to get.
You need to prove what about this set? That it is connected? Or that it is pathwise connected? A set can be "connected" without being "pathwise connected".
Thanks!
