How do I show two planes are neither coincident, or parallel?
  • Thread starter Thread starter Random-Hero-
    Parallel Planes
The discussion centers on determining the relationship between two planes defined by the equations π1: x + 2y - 4z + 7 = 0 and π2: 2x - 2y - 5z + 10 = 0. The normal vectors for these planes are n1 = (1, 2, -4) and n2 = (2, -2, -5), which are not scalar multiples of each other, indicating that the planes are neither parallel nor coincident. The planes intersect along a line, confirming they are distinct. The angle between the planes can be calculated using the dot product of their normal vectors.
  • Understanding of vector algebra, specifically normal vectors.
  • Knowledge of plane equations in three-dimensional space.
  • Familiarity with the dot product and its geometric interpretation.
  • Concept of intersection of planes and their relationships (parallel, coincident, distinct).
  • Learn how to calculate the angle between two planes using the dot product.
  • Study the geometric interpretation of plane intersections in three-dimensional space.
  • Explore the implications of different normal vectors on the relationship between planes.
  • Investigate the conditions under which two planes can be parallel or coincident.
Students studying linear algebra, geometry enthusiasts, and anyone interested in understanding the relationships between planes in three-dimensional space.
Random-Hero-
Show that the two planes are neither coincident, parallel, nor distinct. Identify, geometrically, how the planes intersect and determine the angle between the two planes to the nearest degree.
\pi1: x + 2y - 4z + 7 = 0
\pi2: 2x - 2y - 5z + 10 = 0
I found the normals to be
n1 = (1, 2, -4)
n2 = (2, -2, -5)
Two planes, if they intersect, intersect in a line.
An equation of a plane has the form
nxx + nyy + nzz = d
where \vec n = <nx,ny,nz> is the normal vector to the plane.
It can be shown that the angle between two planes' normal vector equals the angle between the planes. You can use the dot product
\vec n1 dot \vec n2 = |n1||n2|cos(\theta)
But how do I like...SHOW that they aren't either of those without drawing a diagram? Because it looks like like the first part of the question wants me to SHOW they are neither parallel or coincident, and the second part is finding the angle. So how would I show that they are neither parallel or coincident without proving the angle? All I can really think of is the fact that n2 \neqkn1\pi
Well, parallel planes don't intersect, so finding an intersection proves they're not parallel, right? Coincident planes lie on top of one another so showing that they intersect in a line proves that they aren't coincident. But, aren't these two planes distinct, or am I thinking of something else.
I think that maybe my professor just made a typo, because that doesn't make sense, from everything I've found so far, suggest they are distinct. But how do I show that? Do I use the dot/cross product for the parallel and perpendicular things?
I agree. The problem statement is incorrect. Two planes in three-dimensional space (as yours are) must be either parallel or coincident. If they are parallel, they are distinct. If they intersection in a line, I would say that they are distinct, since we can tell them apart, but maybe your prof means distinct in the sense that they share no points at all.
The two planes you are given have different normals, so they must intersect in a line, so it's not possible to prove that they are not parallel, not coincident, and not distinct. It's a little like saying, n is a positive integer - prove that it is not even and not odd.
an inhomogenous system of two equations in three unknowns of the form Ax=b. look at the solution set of this system. if there are no solutions, then the two planes are parallel. if the solution set is a plane, then the two planes are coincident. if the solution set is a line, then the two planes intersect in a line and cannot be distinct (no points of intersection, if i interpret this correctly). it is impossible for the solution set to be a point for a 2x3 system. hope this helps.
  • · Replies 19 ·
12K
