How do I solve for the particular solution using the annihilator method?
  • Thread starter Thread starter Gogeta007
    Differential
7 replies · 5K views
Gogeta007
1. y''' + y'' = 8x^2
2. y'' - 2y' - 3y = 4e^x - 9
Annihilator for any polinomial D^n+1
annihilator for e functions = e^ax = (D-a)^n
1. getting the complementary eq.
values of m = 0, 0, -1
yc= c1e^-x +c2 + xc3
then we multiply both sides by the annihilator
D^3<D^2(D+1)> = 8x^2<D^3>
we get y= c1e^-x +c2 + xc3 + x^2c4 + x^3c5
and from the original eq. the x^2 term has a coefficient of 8
therefore c4 = 8
sice there is no x^3 term then c5 should be zero ?
and what about c4?
the answer on the back says the answer is:
c1+c2x+c3e^-x + 2/3 x^4 + 8/3x^3 + 8x^2
2.values of m=3, 2
yc=c1e^3x + c2e^-x
if we multiply by the annihilator alpha = 1 in this case therefore annihilator would be (D-1)
<D-1><D^2-2D-3>=4e^x-9 <D-1>
so we have
yc=c1e^3x + c2e^-x + c3e^x
how do I go from there?
thank you!
Use the wronskian and cramer's rule.
You should have one more power of x.
therefore c4 = 8
and what about c4?
You're thinking y=8x^2, but it's actually y'''+y''=8x^2. You need to plug your trial solution back into the differential equation and then solve for the coefficients.
2. values of m=3, 2
m=2?
yc=c1e^3x + c2e^-x
so we have
how do I go from there?!
You need a slightly different annihilator since
(D-1)(4 ex-9) = 9
Again, once you get your trial solution, plug it back into the differential equation and then solve for the coefficients.
Thank you all. I have one more
y'' + y' + y = xsinx
The annihilator for xsinx is (D2+1)2 which would yield 4 answers that are imaginary (+i,-i,+i,-i)
when you do the particular solution, since the answers are repeating do you put an x before the constant?
so far i have that yc=e-x/2(c_1cos<(sqr3)/2> + c_2sin<(sqr3)/2>)
then the annihilator values for D
yp= c_3cosx + c_4sinx + c_5cosx + c_6sinx
or is it
yp= c_3cosx + c_4sinx + xc_5cosx + xc_6sinx
and if its the latter, to get the coefficients you have to take up to the third derivative. . .using product rules? (...im hoping not) or is there another "easier" way?thank you
Your complementary solution is wrong. You have a third-order differential equation, so you should have three independent solutions. Yours only has two.
You need the second particular solution you wrote down because you need four linearly independent solutions. You multiply by powers of x to make the repeated solutions independent.
my bad. . .it is double prime not triple.
*edited*
thanks for pointing that out
