How do I solve ∫sin³x cos²x dx?
  • Level: Undergrad
  • Thread starter Ravenatic20
    Integration
17 replies · 6K views · last reply
Ravenatic20
I've been working on this problem for almost 4 days now and have made no progress. Once I think I've got it right, by professor says its wrong, and to try again. I've tried and tried. Any ideas? Here it is:
[tex]\int sin^{3}x cos^{2}x dx[/tex]
You could write everything in the integral in terms of sines, then either:
1. Use reduction formulae for sin^n x
2. write the powers of sines in terms of sines of multiples of x
Try to write the integrand as sin(x) * f(cos(x)) or cos(x) * f(sin(x)), where f is some algebraic function.
I know this is not so formal, but it works:
using the fact that:
[tex]d(cos(x))=-sin(x)dx[/tex]
you get:
[tex]\int sin^{3}(x) cos^{2}(x) dx=-\int sin^2(x)cos^2(x)d(cos(x))=-\int(1-cos^2(x))cos^2(x)d(cos(x))[/tex]
and you are done.
regards
marco
Thanks marco but I need the whole integral solved so the [tex]\int[/tex] sign is removed. And to the point where our constant C is added on: [tex]+ C[/tex].
Do you honestly expect others to just do your work for you. Marco made the problem much simpler for you all it requires now is a simple, and fairly obvious substitution.
No, the last part just doesn't make sense. If someone could explain it I'll take a shot at it, but I've never seen it (d(cos(x)))
do the substitution:
t=cos(x)-----> dt=d(cos(x))
you get it?
regards
marco
Thanks Marco.
This is what I have so far, in continuation of what Marco helped out with:
[tex]=-\int(1-cos^2(x))cos^2(x)d(cos(x))[/tex]
[tex]=-\int(\frac{1}{2}-\frac{1}{2} cos2x)(\frac{1}{2}+\frac{1}{2} cos2x)d(cos(x))[/tex]
[tex]=-[{(\frac{1}{2}x-\frac{1}{4} sin2x)(\frac{1}{2}x+\frac{1}{4} sin2x)] + C[/tex]
Err, is this right? If not how do I fix it? Thanks
No, that's not right.
Do what macro_84 said. let t = cos(x)
Now substitute t everywhere you see a cos(x) in the integrand that macro gave you (the one with nothing but cosines). it's staring you in the face.
Ravenatic20 said:
Err... That did not make much sense, sorry.
How did that not make sense? Are you familiar with integration by substitution? Make the substititution t=cos(x) and what happens?
Well no wonder you couldn't get this integral, you don't understand the most basic method of integration.
Sorry, I've only been doing this for a few weeks. I came here for help, nothing else.
[tex]...=-\int(1-cos^2(x))cos^2(x)d(cos(x))=-\int(1-t^2)t^2dt[/tex]
can you do it now??
ciao
marco
Then stop expecting people to do the problem for you. What has been suggested is that you rewrite the integral as
[tex]\int sin^2(x)cos^2(x) (sin(x)) dx= \int (1- cos^2(x))cos^2(x) (sin(x)dx[/itex]<br /> Now, if u= cos(x), what is du? If you don't know that you should review differentiation before trying integration.[/tex]
