How to Integrate a Differential Equation to Find u?
  • Thread starter Thread starter shreddinglicks
    Differential
The discussion focuses on integrating the second-order differential equation, specifically ##-v(du/dy) = κ(d^2(u)/dy^2)##, to derive the general solution ##u(y) = c_{1} + c_{2}e^{-\frac{v}{\kappa}y}##. Participants clarify the relationship between the variables and constants involved, confirming that ##v## and ##κ## are constants. The method of solving involves transforming the equation into a characteristic equation, leading to exponential solutions. The integration process and the application of logarithmic differentiation are also discussed as key techniques in deriving the solution.
  • Understanding of second-order differential equations
  • Familiarity with exponential functions and logarithmic differentiation
  • Knowledge of characteristic equations in differential equations
  • Basic integration techniques
  • Study the method of solving second-order homogeneous differential equations
  • Learn about characteristic equations and their applications in differential equations
  • Explore logarithmic differentiation and its role in solving differential equations
  • Practice integrating first-order separable equations to reinforce understanding
Students and educators in mathematics, particularly those focusing on differential equations, as well as researchers and professionals applying these concepts in physics and engineering contexts.
shreddinglicks
integrate:
##-v(du/dy) = κ(d^2(u)/dy^2) ##
to obtain:
## (-v/κ)y = ln(du/dy) + c##
and finally:
##u = d + w*e^(-vy/κ)##
## (-v/κ)dy = d(u) ##
which gives:
## (-vy/κ) + C = u ##
##v,\kappa## are constant ? What is ##w## ?
I think there is a mistake here:
shreddinglicks said:
u=d+w∗e(−vy/κ)
did you want to write this ##u(y)=c_{1}+c_{2}e^{-\frac{v}{\kappa}y}##, where ##c_{1},c_{2}## are "generic" constants ?
Ssnow
Ssnow
Yes, sorry about that.
Ok, then ## u(y)=c_{1}+c_{2}e^{-\frac{v}{\kappa}y}## is the general solution...
Ssnow
Ssnow
Yes, but I want to know how to get that solution from the differential equation.
In order to know "how" to find the general solution there is a general method for second order differential equations that consists to pass to the characteristic equation:
## \lambda^2+\frac{v}{\kappa} \lambda =0##
that has solutions ## \lambda_{1}=0## and ##\lambda_{2}=-\frac{v}{\kappa}##. When we have ##\Delta >0## the solution is a linear combination of exponentials:
##u(y)= c_{1}e^{0\cdot y}+c_{2}e^{-\frac{v}{\kappa}y}##
we write simply ##u(y)=c_{1}+c_{2}e^{-\frac{v}{\kappa}y}## (for details on this method I suggest any elementary book on differential equations)
Another way is to observe that:
## -\frac{v}{\kappa}y=\ln{\frac{d u}{dy}} +c ##
is equivalent to:
## -\frac{v}{\kappa}y-c=\ln{\frac{d u}{dy}} ##
that is
## e^{-\frac{v}{\kappa}y-c}=\frac{du}{dy}##
and the differential equation is: ##\frac{du}{dy}=Ke^{-\frac{v}{\kappa}y}## with ##K=e^{-c}## that is a constant.
This admit a simple solution that is the exponential itself, (you can think on this ...)
Ssnow
Precisely ,our equation is a second order homogeneous differential equation ...
Ssnow
is equivalent to:
that is
Ssnow
I understand everything that you showed me except the line:
How does that come from the original differential equation?
This is because ##\frac{1}{\frac{du}{dy}}\frac{d^{2}u}{dy^2}## is equal to ##\frac{d}{dy} \left(\ln{\frac{du}{dy}}\right)##. In fact:
##-v\frac{du}{dy}=\kappa\left(\frac{d^2u}{dy^2}\right)##
is equivalent to
##-\frac{v}{\kappa}=\frac{1}{\frac{du}{dy}}\left(\frac{d^2u}{dy^2}\right)##
that is equivalent to
##-\frac{v}{\kappa}=\frac{d}{dy} \left(\ln{\frac{du}{dy}}\right)##
now integrating both sides respect to ##y## we have : ##-\frac{v}{\kappa}y=\ln{\frac{du}{dy}}+c##.
Ssnow
integrate:
to obtain:
and finally:
which gives:
Set ##w = du/dy## and then write the DE as ##dw/dy = r w,## where ##r = v/\kappa.## Thus, ##w = c e^{ry}## and ##u = \int w(y) \, dy.##
I see, that is useful.
is equivalent to
Ssnow
Is there a proof for:
##\frac{1}{\frac{du}{dy}}\frac{d^{2}u}{dy^2}## = ##\frac{d}{dy} \left(\ln{\frac{du}{dy}}\right)##
The proof is an application of the derivative rule ## \frac{d}{dy}(f(g(y)))=\frac{df}{dy}(g(y))\cdot \frac{dg}{dy}(y)##, where ##f(y)=\ln(y)## and ##g(y)=\frac{du}{dy}(y)##.
Ssnow
Ssnow
Thanks!
Since the problem asks you to integrate use a common method. Let p = du/dy to find a first order separable equation in p. Once you have p you then have u by integration. The method is much more general than this.
  • · Replies 20 ·
