How do I use a turnbuckle effectively?
  • Thread starter Thread starter DaveC426913
    installation
42 replies · 6K views
jack action said:
You have jam nuts. Use the jam nuts. More in the following video about jam nuts and lock wires:
As an obvious point for those that have not watched the video (time 2:40):
Jam nuts ADD to the strain on the threads, making them more likely to strip/fail.
Please keep it in mind!
Cheers,
Tom
OK, I tried google and failed; honestly, I tried. What is a SeaSaw? Bonus points for a picture.
I'd trade you for a picture of my last boat, a C&C 33, but you could just google that.
Baluncore said:
or maximum adjustment range, turnbuckles are usually made with the two bolts,
That's not the only reason . Having a LH and RH thread means you don't need a swivel in the rigging; the only thing that rotates is the body of the turnbuckle.
My turnbuckles used a split pin through the tip of each bolt which wouldn't turn once it met the frame of the buckle (no stress on the bolt at that point). Not very strong and you could bend the pin but I never found one that undid itself.
Aren't you sweet for asking!
MacGregor 26X powersailor with Honda BF50D.
Top sailing speed: 7.0 knots (.6 knots over hull speed)
Top power speed: 14 knots
Baluncore said:
Teeter Totter ?
What do you think I named my dinghy launch? :wink:
Yes. These new $75 turnbuckles have that. My slipmate has a bigger boat with bigger TBs and I see he's taken out the split pins and inserted ring dings.
I think I will follow suit.
Someone elseweb asked for a comparison of the $14 vs. $75 bolt threads:
TT.
Like my 'Lady Mondegreen' and the tender 'Miss Heard'.
Very fiddly to use those rings and you really need strong fingernails. But they work well and don't do the damage that the sharp ends on split pins. Swings and roundabouts.
Baluncore said:
TT.
That's clever!
Totally Agree. I hate em.
That they're all right-hand optimized makes it doubly frustrating.
Exactly.
That assumes both bolts have the same pitch.
Less common LH threads are not required for a "body-only-turning" turnbuckle.
Differential pitch bolts of the same hand, can achieve the same adjustment range, with an optional advantage of length adjustment finer than the thread pitch employed.
https://en.wikipedia.org/wiki/Differential_screw
These bolts wouldn't just be 'out of the drawer of random bolts'. Is it at all unlikely that they would not match, by chance. The two ends could be sourced differently so one just could be weaker than the other but the geometry would be the same for each.
And have you a marine example of a differential turnbuckle? :biggrin: I'd bet you could scour the catalogues for a long time before you found one.
