Homework Helper
- 30,614
- 7,552
This is wrong. The distance between compression regions and rarefaction regions is a quarter wavelength, whatever the amplitude (maximum displacement) of a wave.jsmith613 said:On a slight tangent:
http://s359.photobucket.com/albums/oo40/jsmith613/?action=view¤t=Long.png
Surley the displacement is the distance between an area of compression and an area of rarefaction divide by 2
In a 'real' compression wave, like sound, the actual displacement is a small fraction of a wavelength. A set of equally spaced vertical lines could be used to show the rest positions of small regions of air (/medium) and the displacement from those lines would be hardly visible. As you can plot a variable on any axis you like, you can just as easily show the displacement using an axis at right angles to the direction of propagation - and use whatever scale factor (gain) you want to show the way the displacement varies. So a longitudinal wave can just as easily be represented by a 'wiggly' line. Or it can be shown as varying shades of grey / colour, the darkest representing high pressure and the lightest, low pressure. I think there is a lot of needless confusion about this but XY graphs are usually chosen to represent most relationships between variables because they are easy to plot onto and to read off data.
