How do physicists measure electron position if the wavefunction is everywhere?
143 replies · 16K views
durant35 said:
I have another question. Considering the double slit experiment, during the passing of the electron through both slits, it seems that the electron can be found only in the areas under the obstacle (and not in the obstacle itself). How is that represent by the Heisenberg uncertainty principle, is the obstacle area completely excluded from the probability area so that we can't find the electron in the obsacle and does the electron split the probability areas in two portions of space during the passing through the obstacle?
Many particles will be detected at the barrier (doesn't have to be a dedicated detector there), those do not participate in the double-slit experiment.
BvU said:
Are you familiar with the Fourier transform ?
No mate unfortunately I'm not... How is it related to uncertainty and my question?
A wave packet with a sharp distribution in ##\bf k## (##{\bf p} = \hbar {\bf k}##) has a wide distribution in ##x##: they are each other's Fourier transform (http://www.fisica.net/quantica/Griffiths%20-%20Introduction%20to%20quantum%20mechanics.pdf page 107).
When physicists put an electron in a lab or a box, does that mean that there is a 100 percent change that the electron is in the lab or are electrons capable of being even outside of the lab when we put them inside (in a range of 10 m size let's say)? This is connected with my question about the double slit, if we have a small wall and two slits do electrons treat the wall like a barrier or do they go through the wall and also through the slits?
You are referring to idealized boundary conditions that feature in exercises for beginning students. Experimental reality is a bit tougher, but still the results from these simple exercises often hold to within all practical limits.
The exercises are really useful.
And there is no difference between 100 percent and 100 - 10-659 percent.PS did you read up on the Broglie wavelength ?
That's Feynman's sum over histories interpretation - its an interpretation - the QM formalism is silent on what happens when not observed.
If you want to make progress in QM that's something that needs to be indelibly imprinted into your understanding.
Here is the explanation of the double slit using only the formalism:
http://arxiv.org/ftp/quant-ph/papers/0703/0703126.pdf
Thanks
Bill
Bhobba is perfectly right, but in view of posts #1 and #32 I suggest you don't try to work your way through this article yet. Just keep an open mind and remain as critical as you have thus far proven to be. Do as many exercises as you can. And be glad that the introductory ones are fairly simple :smile:
I agree wholeheartedly. For now simply keep it in mind and a bit later as your understanding progresses then go though it. There is a reason beginner books don't teach it that way. The issue is they don't go back and redo the earlier ideas in light of the new knowledge you have gained. The purpose of the paper I linked to was to correct that.
Thanks
Bill
How does the microscopic (quantum) /macroscopic transition happen? I red that microscopic effects like a range of locations for an electron average out in one interpretation so let's say the Moon is almost precisely where we see it because of it small wavelength? What about molecules, do they average out the atomic and subatomic behavior so it can be said that their position is in a localized region?
I got to add, I am starting to suffer from a kind of existential anxiety because of the lack of knowledge and confusion from examining quantum physics. I've red that 5 years ago a scientist made a superposition of 'vibrating-non vibrating' states of a 60 micrometer thing. Can somebody explain that and the relation to macroscopic phenomena. Any help and constructive advice would mean so much to me.
Here is the experiment:
http://www.nature.com/news/2010/100317/full/news.2010.130.html
What they did is remove the environment that would usually observe it so quantum effects can manifest.
Thanks
Bill
So can we describe let's say bacteria and cells with adequate determinism, so those entities behave classically and without superpositions (unless we go radical and induce an experiment like the Schrödinger's cat experiment?
That's exactly what Schrödinger's Cat demonstrates. That if you remove the environment that observes it, the cat becomes a quantum object.
Could a Scrodingers cat be constructed in principle in everyday life? Is the random event, the atomic decay obtainable in our level? Basically I want to know why don't random quantum events trigger something on the macro scale and how would the Schrödinger cat experiment be obtainable in practice, in what conditions?
The set-up is easily constructed.
What you can't do is have the cat in a live-dead superposition because the cat breaths air that decoheres it. And it is not the only thing in the set-uo that does that - even sitting on the stool will do it.
And no, from many many discussions on this I can assure you there is no way around it - a cat can't be in a superposition - end of story. So please, please, do not go down that path - do a search here on other threads. It will go nowhere just like those other threads. A cat is entangled with its environment by the definition of a cat - no escaping it. Don't ask - but if you could do it what would happen - you can't - forget it.
Thanks
Bill
Thanks
Bill
But decoherence isn't an instanteneous process, right? So upon what do you think that a can't be in the mixture of states for an instant?
A cat is decohered from the moment of its existence as a cell in its mothers womb. There is no way to avoid it from what a cat is.
Thanks
Bill
So what's the difference between the cat and the small item which that the scientist used in the article you posted about?
It was isolated from the environment ie no atmosphere, at near absolute zero, shielded from vibrations etc etc. Even then its not entirely isolated - its impossible to do that. From QFT the particles of whatever obect you are considering is entangled with the quantum vacuum that pervades all space. Since that vacuum is the ground state of all fundamental particles I can't see how you can stop that entanglement, but won't rule it out with future progress. Certainly you can't do it now. It this that leads to the strange phenomena of spontaneous emission so that even the human body is a black body source:
https://en.wikipedia.org/wiki/Black_body
Thanks
Bill
Ok Bill, thank you. One more question regarding the Schrodingers cat in theory, once the cat gets entagled with the radiation emitter from the beginning of the experiment, it still behaves classically until the moment it gets hit/doesnt get hit by poison, then it enters the superposition? Conceptually and theoretically speaking of course.
Does the experiment imply that there are more than two possibilities depending on the time the atom decays? So on a time scale cat is in a superposition at t1, cat is in a superposition at t2 and so on as possibilities?
Our ideal non-breathing and in general non-interacting (not even with itself) cat would have to be isolated all the time - the point of the experiment is that you cannot determine from outside if the radioactive decay happened or not. As long as you observe the cat, you know that.
The state changes gradually from "the cat is alive" to "the cat is in a superposition of alive and dead" where the dead contribution increases over time.
By the way: the past tense of "read" is "read".[/size]
Their is a lot of rubbish written about Schroedinger's Cat. The purpose of the thought experiment was to highlight a subtle problem with the then prevailing Copenhagen interpretation to do with where to place the Von Neumann cut. No one seriously considered the cat in a superposition of alive and dead. As a living macro object that's impossible. With our better understanding of decoherence that issue is now resolved - the most natural place to put the Von Neumann cut is just after decoherence which in the Schroedinger Cat experiment is at the particle detector. I have read that from the way particle detectors work its actually a bit before the flash or click or whatever indicates the radioactive decay but that is neither here or there. From that point on everything is common-sense classical. Cats can never be in a superposition of alive or dead.
In fact due to the set-up its entangled with the radioactive source. You can analyse it from that viewpoint and it shows it can't be in a superposition of alive and dead:
https://www.physicsforums.com/threads/is-the-cat-alive-dead-both-or-unknown.819497/page-3
See post 43.
But you know that anyway from what cats are.
Thanks
Bill
See post 43.
Thanks
Bill
So neither the detector nor anything macroscopical is in a superposition, decoherence occurs during the transition and washes away the effects so that everything is classical?
I don't know what you mean by that. It occurs in the particle detector. Exactly what happens there you will need to consult how such detectors work.
Thanks
Bill
Can an atom decay in everyday life have similar influences to transfer randomness to other stuff? Does macroscopic radiation emerge from the quantum microscopic randomness?
You are getting way off topic - if you want to pursue it start a new thread or threads.
But yes in real life atomic decay can lead to macro effects eg it can cause cancer. EM is the classical limit of QED.
Thanks
Bill
I didn't mean to get off topic, I was wondering can an random atomic decay in normal circumstances cause a superposition on a macro level. You must've meant that radiation emerges from decay of atoms with your last sentence, and that the cancer is caused with the radiation in general as a classical concept, since you mentioned that classical ED emerges from QED. Thanks in advance.
