How do Shifts Affect Invertible Functions?
  • Topic:
  • Thread starter Thread starter renyikouniao
    Functions
17 replies · 3K views
renyikouniao
Show that if f(x) is an invertible function then g(x)=f(x)+c is an invertible function.If f^(-1) is known what is g^(-1)
Thank you in advance
a) Does adding a constant to a function affect its monotonicity?
b) What effect does the constant have on the range of $g(x)$, and hence on the domain of $g^{-1}(x)$?
No,it doesn't
I have no idea on this part
Suppose we have the monotonic function:
$$f(x)=e^x$$
We know its range is $$(0,\infty)$$.
So, what is the range then of:
$$g(x)=f(x)+c$$
What relationship exists between the range of a function and the domain of its inverse?
$$f(x)=e^x$$
$$g(x)=f(x)+c$$
The range of g(x) also is (0,infinity)
The range of f(x) is the domain of g(x),the domain of g(x) is the range of f(x)?
Adding a constant to a function has the effect of shifting it vertically, thereby affecting its range. The range of $g(x)=e^x+c$ is therefore $(c,\infty)$. So then what would the domain of $g^{-1}(x)$ be, and how do we shift the domain of a function?
the domain of $g^{-1}(x)$ would be $(c,\infty)$
Correct, so how would we shift the domain? How do we shift a function horizontally?
shift c units horizontally?
Yes, how would we shift a function $c$ units to the right?
I don't get this...
Suppose $f(x)$ has a root at $x=c$, or $f(c)=0$. Then $f(x-h)$ will have a root at $x-h=c$, or $x=c+h$. Hence, $f(x-h)$ is the graph of $f(x)$ shifted $h$ units to the right. So how can we apply this to the original problem?
So..the original function has domain:c,infinity. range:0,h
the inverse function has domain:0,h. range:c,infinity
Let's go back to the original question...
a) We are given that $f(x)$ is an invertible function, and then we are asked to then show that $g(x)=f(x)+c$ is also invertible.
While we have observed that adding a constant to a function does not affect its monotonicity, how can we explain/demonstrate this mathematically?
b) We are asked to give $g^{-1}(x)$ in terms of the known $f^{-1}(x)$.
We have observed that the graph of $g(x)$ is shifted vertically from that of $f(x)$, hence the graph of $g^{-1}(x)$ must be horizontal shifted (by the same amount) from that of $f^{-1}(x)$. So how can we state this mathematically?
It should be noted that f(x) is not requested to be continous, so that monotonicity is not a necessary condition for f(x) to be invertible. For example the function...
$$f(x)=\begin{cases} -2 - x \ \text{if}\ -1< x < 0\\ 0\ \text{if}\ x=0\\ 1 + x\ \text{if}\ 0< x< 1 \end{cases}\ (1)$$
... is invertible even if not monotic... Kind regards $\chi$ $\sigma$
Another example: $$f(x)=\begin{cases} x &\mbox{if}& x\not\in\{0,1\}\\ 0& \text{if}& x=1\\ 1 & \text{if}& x=0 \end{cases}\Rightarrow \exists f^{-1}\;\wedge\;f^{-1}=f$$
First, some metamathematical remarks. I admire Mark's patience in explaining the effect of adding a constant on the range of a function, but I find the whole first page hard to follow.
I am not sure it is necessary to talk about the relationship between the domains of $f^{-1}$ and $g^{-1}$ because if the domain of some function $u$ is $D$ and the domain of some $v$ is $\{x+c\mid x\in D\}$, it obviously does not follow that $v(x)=u(x-c)$.
I am not sure it is helpful to talk about graph shifting, either. I am pretty sure that if the OP did not know how adding a constant changes the range, s/he would be lost by the fact quoted above. Horizontal graph shifting is counterintuitive because adding a positive constant to the argument leads to the graph's shift to the left rather than to the right.
And it has been pointed out that instead of monotonicity of $g(x)$ we must show its injectivity.
I think it is much easier to focus on algebra involving concrete numbers $x$ and $y$ instead of talking about domains or graphs as a whole.
So, we have $g(x)=f(x)+c$ and we need to find $g^{-1}$. This means we need to solve the equation $f(x)+c=y$ for $x$. It is solved in the usual way: we look at operations applied to $x$ in the left-hand side and reverse them. There are two operations applied to $x$: first $f$ and then adding $c$. Therefore, we first have to subtract $c$ from both sides to neutralize addition, and then ... (use the fact that $f^{-1}$ is known).
All I was trying to impart is that if the graph of $f(x)$ is shifted up $c$ units to get $g(x)$, then the graph of $f^{-1}(x)$ will be shifted to the right by $c$ units to get $g^{-1}(x)$. This immediately leads to the result we find from the algebraic approach.
