How do spring-loaded pipes dampen vibrations in hydrostatic systems?
  • Thread starter Thread starter Andrea Vironda
    Hydrostatic System
7 replies · 2K views
Andrea Vironda
Hi,
In some hydrostatic tables I can see many spring-shaped pipes that are traversed by oil.
Spring is responsible for a kind of dampening that I ignore how to deal with.
Do you have any idea of the physical principle behind it?
The "spring" = helical pipe, has a great length without sharp corners. The viscosity of the oil flowing in the long thin pipe wastes energy, and so damps movement.
Thanks Baluncore.
What's the law governing this behavior? Navier-Stokes?
I was confused by the title, since "Hydrostatics" implies that the fluid is not moving. Is this more about how to damp motion in a flowing fluid? I can change the thread title if that would help to make it more descriptive. :smile:
https://en.wikipedia.org/wiki/Hydrostatics
@berkeman
I am also guessing wildly here, which certainly makes it interesting.
I suspect it is a static fluid support for a large and heavy slab of material, such as a granite precision surface plate. I think it is hydraulic damping of the static position, so maybe only stress reduction?
@Andrea Vironda
What is the table used for. Is it optics, machining or metrology ?
We need a manufacturer and model number, or a link on the web, to a picture of a similar table, with coils of tubing between supporting bladders?
This table is used for machining. I have this marketing image in with you can see a general layout (column is around 6m tall).
The main advantage in using hydrostatic technology is vibration dampening.
The hydrostatic rotary tables are the 2 scrolling on the blue bases
Are the mentioned coils visible in that image?
