How Do Starting Points Affect Series Comparison Tests?
  • Context: Graduate
  • Thread starter Thread starter PFuser1232
    Comparison Series
3 replies · 2K views
PFuser1232
Comparison Test
Consider the two infinite series ##\sum a_n## and ##\sum b_n## with ##a_n,b_n \geq 0## and ##a_n \leq b_n## for all ##n##.
If ##\sum b_n## is convergent so is ##\sum a_n##.
If ##\sum a_n## is divergent so is ##\sum b_n##.
Limit Comparison Test
Consider the two infinite series ##\sum a_n## and ##\sum b_n## with ##a_n \geq 0## and ##b_n > 0## for all ##n##. Define:
$$c = \lim_{n \rightarrow \infty} \frac{a_n}{b_n}$$
If ##c## is positive and finite then either both series converge or both series diverge.
Does it matter if the two series we're comparing have different starting points? I don't think it matters because we can always strip out a finite number of terms from one of the series until both series have the same starting point.
http://tutorial.math.lamar.edu/Classes/CalcII/SeriesCompTest.aspx
But according to this link, "in order to apply this test we need both series to start at the same place."
You are removing a finite number of terms because you care about different starting points.
Sometimes it possible to change index in order to have series from a determinate point, as example from ##\sum_{i=1}^{\infty}a_{i}## putting ##i-1=k## we have ## \sum_{k=0}^{\infty}a_{k+1}##...
The limit is as ##n \to \infty##, so the starting points of the two series don't matter.
