How do we model water flow problems?
14 replies · 2K views
tp86
Homework Statement: Sorry there is no homework statement with this problem
Relevant Equations: n/a
Hi guys. This is my first post here. I love physics but I am unsure how do model water flow type of problems. If anyone could please help us with how we can analyse this it would be much appreciated. It not homework but a problem we are having on our property with water flow.
Please see the diagram I made below for our current situation. There are 2 outlet pipes that go to 2 pumps and would like to know how much additional water flow and pressure the outlet that is connected to both tanks would have? I do not need a precise answer but would like to know physically how i would model this and if it would likely have much more flow (as in 10% more 20% more or 50% more etc) Note: I do not need to know the actual exact water flow value but more of a percentage likelyhood - that's all
2 large water tanks equally filled (notice coupling pipe between them) supplies water to 2 different outlets at the bottom. One received water from only 1 tank, and the other from both tanks at once.
Additionall info:
- Both water tanks are on flat ground and filled to the same level
- All pipes are of same diameter
- All outlets and coupling are at the same height from ground
Is anyone able to help me model this please? I have never done any water flow type of problems in physics and not too sure where too being.
Thank you in advance :)
:welcome: !
How about reading a book on fluid flow to grasp the physical principles ? PF isn't into lengthy lecture series, I'm afraid.
But if you are determined enough, you could work through pressure drop calculations (e.g. here, with a useful equation here. Or find a calculator to do the work.
Your system is pressure driven; with a bernoulli equation and pressure drop calculations you should be able to get some results. Provide a lot more detail (drawings, pipe data) if you want an example.
If the pipe between the tanks is wide enough, both tanks should empty at the same rate.
Reply
I'd start with incompressible, inviscid líquids (Feynman 's "dry Walter").
Hi BvU. Thank you for the info and the references. I've had a quick read but not properly yet as Im beginning to see its quite involved to analyze properly!
Thank you for the suggestion also Gordianus.
This brought me to the idea of analyzing the water (lets pretend its inviscid) and instead of water atoms, could we model them as tiny steel ball bearings and use a basic Newtonian model.
All the ball bearings have a force on them due to gravity. The movement will be complex like fluid dynamics but it is not hard to see at the point with the T intersection there will be momentum from 2 directions joining together.
Please see this demonstration I made
And this resulting momentum should cause the ball bearings to bounce off the insides of the pipe and cause an additional flow of balls at the output (compared to the output that doesn't converge from 2 tanks)
Similarly, this system should produce very similar results to a situation where there is only 1 tank and one output has only 1 output from the tank and the other output has 2 outputs from the tank.
I'd love to know what you guys think of my simplified analysis
I don't think the steel balls are a good analogon for fluid flow.
Here's another link with more focus on flow analysis.
For your casus:
  • What is a typical flow
  • Wat is the pipe (internal) diameter
  • What are the pipe lengths
  • What is the tank diameter
  • Height difference from fluid level to tank exit ?
Thanks mate. I'll have a read today. Just for a bit of further information the reason for the question is that we actually have a large water pump connected to each of the 2 outlets. One of the pumps is making a very loud rattle (I suspect it to be the pump connected to the pipe that is fed by only 1 tank)
And the one with much less rattle being the one being fed by both tanks.
So our theory is that one of the pumps is being staved of water flow / pressure
We were not looking for exact calculations so much, but from the more I read, it really depends on things like pipe diameters and lengths and for that you really need to use the proper equations
Part of the problem is the manufacture has raised the pumps (on a pump stand) about 1.5m from the ground. Of course at this height the pressure and flow will be less
Reply
Hi mate. I did a quick sketch.
I've only shown 1 tank to simplify it a little. So the large water tank is a reservoir we use in case we run out of mains water pressure. The large tank feeds the pump you see on the right (this is actually for an automated carwash)
So the PVC pipe length in total I would say would be somewhere around 20m in total and I believe the pipe diameter is about 50mm (I might have to check on this tomorrow morning though when Im there)
You asked, cavitation or rattling. Personally I think the problem may have started off as cavitation and over a couple of years it's escalated to metal on metal rattling. I do not know if the lack of pressure has caused damaged or not
The actual pump specifications are on here https://arimitsupumps.com/wp-content/uploads/2022/12/model_TR709KV.pdf
It states on there inlet pressure should be -5 to 70psi.
If the pump is trying to feed in water fast and there is not enough pressure keep up, cavitation will defiantly occur near the inlet and will cause damage to pump for sure. I do not know for sure that's what happened but its a possibility
It is an interesting problem. You could almost make an experiment with a straw forking off to 2 pipes, going into the bottom of a water reservoir - like a plastic bottle. vs a normal straw going into a plastic bottle. Then try drink from each of the straws to see if there is much noticeable flow difference and how the height of the straw from the top of the reservoir effects the flow.
Just an idea I had
Turns out there exists a carwash forum. Nothing useful there ?
couple of years sounds like far too long for disaster to strike...
tp86 said:
Says inlet diam is 1.25 times 25.4 mm
The website has a troubleshooting guide; looks pretty thorough and knowledgeable (i.e. what I know is peanuts in comparison -- just a simple physicist)
or is it a pump
And that's where it ends ? With a cork or a nozzle ?
With 15 GPM (10-3 m3/s in understandable units) typical flow and 1.25 times 25.4 mm pipe diam you have input info for the engineering toolbox goodies to estimate pressure drops (which may or may not be important in this casus).
Hi mate. yep the single 50mm pipe that travels underground which actually forks off to 2 identical arimitsu pumps. So it needs to supply enough pressure for both
We have another site where the reservoir tank is positioned on the 1st floor of our building and pump on the ground floor so there is a lot of pressure on the water where the pump is located. Because of this the pumps make half the noise of the pumps at the site with the green tanks explained in this post.
This tends to make me think it is indeed cavitating to some extent. However I dont know if cavitation would be enough to eventually cause metal on metal damage. Usually cavitation has a much greater effect on the rubber seals of the pump.
I've posted on that carwash forum a couple of times. Good point I'll post on there but I assume they will suggest to a tank on our roof for increased pressure. We were just wondering if a simple plumbing solution as described in the original post would make a significant difference as it would only cost us $300 or so to get a plumber in versus $5k-$10k
A diagram of the total system from inlet (the open reservoir surface) to outlet ( where the water exits the pipe) would be necessary to do some calculations. I’m skim reading a bit on my phone, but it seems like you are only giving a partial schematic. Here and there.
They don’t have to be fancy, just some lines and labeled boxes to start. Elevations (relative) are important. Pipe lengths/diameters. All the pump(s) performs curves. With the parallel flows, pumps etc it can be tedious to solve the resulting nonlinear system. However, maybe something useful can be found even if we don’t get that far.
If you are having difficulty, I try to draft up an example highlighting the important info. to a made up system for reference.
Thanks erobz. I noticed last night the fine mesh on one of the filters was partily blocked and after cleaning it has reduced cavitation quite a lot. I think we will pay a plumber to come in to add the additional feed and also to use a drain cleaning device to try to unblock the pipes in case they are blocked. The seem to have a lot of calcification from the normal water and possibly organic type matter inside from dead birds etc.
I have a photo. Any guess what it might be?
If we still have issues after that we will illustrate a through diagram and try to go through all the math :)
Looks like something biological to me. Is it squishy or rock like? Thats the extent of my troubleshooting experience with that stuff though. I would have to use my "phone a water treatment friend" lifeline.
Reply
Welcome, tp86!
This is the way to estimate the conditions your pumps are working at after the plumber cleans the pipes and filters:
https://www.engineeringtoolbox.com/npsh-net-positive-suction-head-d_634.html
I would recommend repairing the noisy pump before the damage progresses.
If cavitation has actually happened, you will find several parts in need of replacement.
Please, see also:
https://easterncapeindustrialnews.co.za/what-you-need-to-know-about-cavitation-in-piston-pumps/
https://www.csidesigns.com/blog/articles/what-is-pump-cavitation-and-how-to-prevent-it
If everything fails and the problem persists, try to add a booster pump (relative low pressure and capable of supply more than 30 gpm) to the point upstream the underground pipe.
Hi mate. Thank you for the info. I have been reading the first link this morning. I need more time to analyze it throughly but in the meanwhile we'll get the plumber to do those basic things.
Cavitation has occurred on the pump for about 1 month so I believe we will have to put in a rebuild kit on the old pump.
I have a feeling when we get the pipes properly cleaned it should help a lot as cleaning the filter thoroughly stopped the rattling form cavitation a great deal.
I'll post an update to let you know what solves it
It's not rock like, it is soft and squish so I also believe it is some sort of organic matter. We will see if the plumber can use the cleaning oscillating tool to scrape it all out.
Reply
