How Do You Calculate Dissolved Oxygen Content for Catalytic Oxygen Removal?
  • Thread starter Thread starter Dean04
    oxygen
The discussion revolves around calculating the dissolved oxygen content in the context of a project involving the catalytic removal of oxygen from water using hydrogen. The focus is on developing a theoretical model to compare with experimental results from a designed deoxygenating system.
  • One participant seeks an equation to calculate dissolved oxygen content for comparing experimental results with theoretical designs.
  • Another participant requests more context to provide a meaningful response, indicating the initial query lacks sufficient detail.
  • The original poster later clarifies the context of their university dissertation, detailing the experimental setup involving a catalytic process with hydrogen and platinum on alumina pallets.
  • A participant suggests that the main question pertains to modeling a catalytic reactor that removes oxygen from water and asks for clarification on whether the hydrogen is in bubble form or dissolved in water.
  • The original poster confirms that hydrogen is in bubble form and acknowledges the need for guidance on modeling catalytic reactors, suggesting that it may require more extensive resources.
Participants express a lack of consensus on how to approach the modeling of the catalytic reactor, with some seeking more information while others indicate that the topic may exceed the scope of the discussion.
The discussion highlights limitations in the initial query regarding the necessary details for modeling the catalytic process, as well as the complexity of the subject matter that may require additional resources for comprehensive understanding.
Dean04
As part of my project I am taking part in an experiment which involves the catalytic removal of oxygen through the use of hydrogen.
Is there an equation to calculate the dissolved oxygen content so that I can compare the experimental results to theory
Thanks
You're going to need to provide more detail than this. Put yourself in our place. There is virtually no context for answering what you are asking.
Chet
Chet
Apologies for such a vague thread. I'll try my best to explain in more detail. My University dissertation is the " Design of a Compact Deoxygenating System for Offshore Seawater injection"
There is an experiment involved which verity's the deoxygenation of water though a catalytic process. The water is fed through a test tube along with hydrogen until it meets the catalyst which is platinum on alumina pallets and then finally into a beaker. The dissolves oxygen content is measured through the use of a vernier dissolved oxygen sensor. This is repeated with the water at different temperatures and flow rates.
Once I have designed a deoxygenating system I want to compare my design with the experimental results in order to prove it actually works. However, as my design is just in theory and not real life I am looking for an equation in which I can use the parameters in my proposed design to calculate the dissolved oxygen content and compare it with the experimental results. My design will have the same principle as the experiment in the fact that the use of hydrogen and a catalyst will remove the oxygen levels.
Hope this is more clear.
Thanks,
Dean.
You are trying to model a catalytic reactor that removes oxygen from water by reacting with hydrogen. The hydrogen is in the feed to the reactor. Is it bubbles or is it also dissolved in the water? Your main question is, "how do I model such a catalytic reactor." Is this correct?
Chet
Bubbles and yes that's correct
The basics of how to model catalytic reactors is beyond the extent of the material that we can conveniently present here. You need to get yourself a book on Chemical Reaction Engineering.
Chet
9K
  • · Replies 27 ·
