How Do You Calculate Maximum Speed in Spring Oscillations?
9 replies · 3K views
K3nt70
[SOLVED] More Spring oscillation
A 2.20 kg mass is attached to a spring and placed on a horizontal, smooth surface. A horizontal force of 17.6 N is required to hold the mass at rest when it is pulled 0.200 m from its equilibrium position (the origin of the x axis). The mass is now released from rest with an initial displacement of xi = 0.200 m, and it subsequently undergoes simple harmonic oscillations. Calculate the maximum speed of the mass.
I've calculated the following already:
Spring constant is 88.0 N/m
Oscillation frequency is 1.00 Hz
This is pretty much the problem; i don't know what equation to use to get the max velocity
Ive been messing around with V = -AwSin(wt) but i can't fathom how to get amplitude..
mkay, well the only thing i can see close to amplitude is Xi. But if that's amplitude, then all i have left to find is time..
xi is indeed the amplitude. However, there is no need to consider the amplitude, period, angular velocity etc. This problem can be trivially solved using conservation of energy.
Ek = 1/2 mv^2, but i don't have kenetic energy...
Ep= 1/2 kX^2 <-- is this the equation you're referring to?
Indeed it is, and since energy is conserved you can use this to determine the velocity of the mass at any point.
woohoo! Thanks for your help!
