How Do You Calculate Mechanical Advantage in a Nail Puller?
6 replies · 6K views
Armando Valle
What is the mechanical advantage of a nail puller where you exert a force 45 cm from the pivot and the nail is 1.8 cm on the other side? What minimum force must you exert to apply a force of 1250 N to the nail?
2. Homework Equations
MA= FO/FI * LI/LO
Ive tried to make the problem but i don't understand it, can someone help me? thanks!
MA= FO/FI * LI/LO
What have you tried? What's the geometry of a nail puller? Have you drawn a diagram and labelled the forces? A "pivot" implies that torques may be involved. What have you done to investigate this?
Ive tried to use the MA equation but i don´t find a relationship with the forces included on the problem. this are the images of the problems, thanks!
I don't understand your relevant equation ("MA equation") as presented. Can you define the variables?
this are the equations
Your Relevant equation:
MA= FO/FI * LI/LO
does not reflect what is in your latest image. It should be:
MA= FO/FI = LI/LO
Note the "=" between the terms. So you're dealing with ratios.
Can you pair up the given values in your problem with the variables in your equation?
The figure for OP's problem together with said equations.
