How Do You Calculate Projectile Motion from a Cliff?
  • Thread starter Thread starter fcb
    Projectiles
The problem involves calculating the time of flight for a projectile fired from the top of a 10m high cliff, with a range of 152m and a maximum height of 8.2m above the cliff. Participants are exploring the relationships between vertical and horizontal motion in projectile motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of time of flight using various equations and assumptions about initial vertical velocity. Some question the relevance of the range in determining time, while others suggest that it is necessary for a complete analysis. There are attempts to apply the quadratic formula and different kinematic equations to find time.
There are multiple interpretations of how to incorporate the range into the calculations. Some participants have provided calculations and results, while others are seeking confirmation of their findings. The discussion reflects a mix of agreement and differing approaches, with no clear consensus on the correct time of flight yet established.
Participants are working under the constraints of a homework assignment, which may limit the information available for solving the problem. There is also uncertainty regarding the initial vertical velocity and how it relates to the overall motion of the projectile.
fcb
A projectile is fired from the top of a 10m high cliff. It has a range of 152m and reaches a maximum height of 8.2m above the cliff top. Determine the time of flight
Is Delta Y =18.2?
Is Uy=10
Delta Y = Uyt + 0.5 ayt
18.2=10t-4.9t2
4.9t2-10t+18.2
Using the quadratic equation
10+-21.37/9.8
t=3.2
Does that seem right
I believe delta y would be 18.2, and your work seems right.
Thank you Drelt
You have not used the range of the projectile any where.
Where would range play a part in the question? Doesn't range (delta)x only matter on horizontal motion?
I mean if you can find time the you can find Ux but I didn't know you needed to use it to find time
Since range is given, the projectile is fired with some angle with the horizontal line.
In the problem they have not given uy = 10 m/s.
So is the time not 3.2 since I assumed Uy was 10m/s?
Wouldn't I need to know U to be able to find Uy then. And Ux would be range over time. But how would you find time without finding Uy
Could you make Vy=0 and use the equation
Vy^2 = Uy^2 + 2a (delta) Y
Yes. You are right.
Uy = (2*g*y')^1/2.
Ux*t = 152. So t = 152/Ux.
Now -y = Uy*t - 1/2*g*t^2
-y = (2*g*y')^1/2.*152/Ux - 1/2*g*(152/Ux)^2
Solve the quadratic to find Ux, and then find t.
I got t= 3.18
Is that right. Maybe I screwed up somewhere along the line.
I'll double check in the morning as I am in Australia and it's getting late
all looks good, just double check the quadratic work in a calculator on n the computer to make sure you didnt make any mistakes.
Nah I think there was a mistake. Can Someone confirm with me that t=~1.903
Im not sure if I am correct or not, but when I did the problem i got t= 4.642s
I used the equation (deltax)= v(initial)t + (.5)(9.8)t^2
Step One) 152=10t+4.9t^2
Step One rearranged for quadratic formula) 4.9t^2+10t-152=0
Got answers 4.62s and -6.683s, but time cannot be negative so i ruled out the second answer
hello :)
Let the projectile is projected with velocity 'u' making an angle A with horizontal.
Let us break the motion in 2 parts :-
<1> From point of projection to maximum height of 8.2m above the cliff top :-
{...For a projectile, projected with an angle A and velocity u,time of flight when the projectile fall back to same horizontal is t =(2usinA)/g
Time to reach max height, tm= (usinA)/g
Maximum height attained H = (usinA)tm - (1/2)g[tm]2
........= (1/2)(usinA)2/g
...} Using this for Case 1 :-
8.2 = (1/2)(usinA)2/g
=>(usinA)2 =16.4g
Thus,time to complete this part of motion, t1 =(usinA)/g = (16.4/g)1/2
<2> From maximum height of 8.2m above the cliff top to end of flight :-
At max height, only horizontal comp of velocity is there.
Thus initial velocity is ucosA in horizontal direction.
Displacement in vertical height = -(8.2+10) = -18.2m
Thus, -18.2 = 0*t2 - (1/2)g[t2]2
=> t2 = (36.4/g)1/2
Thus, time of complete flight = t1 + t2
.......=3.22 s (approx)
Hope this helps :)
Briliant Vissh. Answer seems consistent with fellow class mates. You're an absolute legend
I think they're different component of x and y and thus you can't use them without linking time
Hehe no problem buddy ^.^
[But Please don't over praise xD When u will continue practising , you will also be able to think of different ways of approach :) And solve problems quickly :)]
  • · Replies 23 ·
