How Do You Calculate Rocket Initial Velocity Using Acceleration and Time?
The discussion revolves around calculating the initial velocity of a rocket using acceleration and time, specifically in the context of a rocket's motion under the influence of gravity. The original poster presents a scenario where the time interval is 4 seconds and the acceleration due to gravity is -10 m/s².
  • Participants discuss the interpretation of the acceleration and its relation to the rocket's motion, questioning whether the scenario involves only gravitational forces or if other forces from the rocket's propulsion should be considered. There is also a suggestion to clarify the full problem statement for better understanding.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have provided insights into the nature of the motion, suggesting that the rocket's trajectory may resemble projectile motion. There is no explicit consensus yet, but various lines of reasoning are being examined.
Participants note the importance of distinguishing between vertical and horizontal components of motion, as well as the need for clarity regarding the initial conditions of the rocket's launch.
python1
I need to find the initial velocity of a rocket using the method a=[tex]\Delta[/tex]v/[tex]\Delta[/tex]t. Given a situation where [tex]\Delta[/tex]t = 4 seconds. The force of gravity in this case is -10(m/s)
After I get [tex]\Delta[/tex]v how do I turn that into the initial velocity?
a=[tex]\Delta[/tex] v/[tex]\Delta[/tex] t
-10=[tex]\Delta[/tex] v / 4 seconds
[tex]\Delta[/tex] v = -40 (m/s)
Welcome to PF.
What you found was the speed of an object dropped after 4 seconds ... or if you are talking about a rocket, the speed in accelerating from rest at 10 m/s2.
The acceleration of gravity while of interest doesn't say anything about the force the propellant delivers to the motion of a rocket.
This is just after launch so I see no need to worry about any force acting on the rocket while it's in the air other than gravity pulling it down.
can you type the full question please, it sounds fuzzy like this
A rocket has been in the air for 4 seconds from the instant it was launched to when it hit the ground. The force of gravity can be rounded to 10(m/s). Using the method a= delta v / delta t, find the initial velocity for the rocket.
you mean 10 (m/s^2)
wouldn't that motion of the rocket be a bow like motion [projectile motion]since it didn't mention that it was verticly launched!
if so work on the vertical axis, where the final velocity=0 and the intial one v [as you did], then try to find the distance from start point to hit point to get v horizontal which is constant [not accelerated] then add both to get the initial velocity [v_i=squareroot(v_v^2+v_h^2)]
OK. So it is not about the rocket at all except that it is a projectile after launch?
In which case the usual rules apply.
V = Vo - a*t = Vo - g*t = Vo - 10*t on the way up and then again on the way down.
With that in mind, then by symmetry it takes 2 seconds up, and 2 more down.
At 2 seconds to max height, then initial velocity is ...
  • · Replies 30 ·
  • · Replies 47 ·
