How Do You Calculate the Initial Distance in a Spring Compression Problem?
  • Thread starter Thread starter krisrai
    Ball
7 replies · 5K views · last reply
krisrai
A 3-kg mass starts at rest and slides a distance d down a smooth 30o incline, where it contacts an unstressed spring. It slides an additional 0.2m as it is brought momentarily to rest by compressing the spring (k=400 N/m).
Find the initial separation d between the mass and the spring.
Work=F*d
Ek=1/2mv^2
Espring=1/2kx^2
v2^2-v1^2=2ad
d=vt
Fg=mg
I know that vf=0
and that v1=0
I really need help with v2 but I am not too sure how to go at it.
is this way of finding v correct even though the balls velocity is at an angle:
1/2mv^2=1/2kx^2
v= sqrt16/3 m/s
can anybody please help?
1/2mv^2=1/2kx^2
v= sqrt16/3 m/s
I assume v2 is the speed when the ball first contacts the spring. Your calculation is almost right, but you forgot about gravitational PE, which changes as the spring is compressed.
While there's nothing wrong with calculating v2 to solve this problem, you can also solve this problem without finding v2. Just compare initial and final energy.
would someone further clarify how to solve this problem?
if you are to compare initial and final energy, should it be:
mgh= 1/2kx^2 ... solve for h?
h= xsin30
Assuming h is measured from the lowest point, yes.
h= xsin30
No. (x is given, by the way.)
okay, so here it goes:
mgh=1/2kx^2
(3kg)(9.8)(sin30h)= 1/2(400N/m)(0.2m)
solve for h
h= 2.72 m
correct?
gravitational potential energy being converted to kinetic energy
mgh=1/2kx^2
Here, h is the vertical distance between the starting point and the lowest point.
solve for h
h= 2.72 m
I think you mean "d" instead of "h". Two problems:
(1) You forgot to square the 0.2m.
(2) Here, "d" would be the entire distance the mass travels along the incline, not just the initial separation between the mass and the spring (which is what you need to find).
More like gravitational PE converted to spring PE.
correct, d would be the entire distance the mass travels along the incline.. so then, how would you go about finding the initial separation between the mass and the spring?
(3kg)(9.8)(sing30d)=0.5(400n/m)(0.2)^2
d= 0.544 m
would you subtract 0.2 m?
