How Do You Calculate the Resistance of a Spherical Resistor?
  • Thread starter Thread starter stunner5000pt
5 replies · 3K views
stunner5000pt
There is a spherical resistor witn an inner radius a and outer radius of b. The outer surface and the inner surface are covered with conducting sheets. Find the resistance between the two surfaces assuming uniform resistivity [tex]\rho[/tex]
WELL
I know [tex]R = \rho \frac{L}{A}[/tex]
If i divided the sphere into many cylinders then each cylinder would have a length of (b-a) and then the area would be ab times the radius (b-a)?
so then i end up with [tex]R = \rho \frac{1}{(b-a)ab}[/tex]
but that isn't right because i know the answer has something to do with 4pi? plase help!
This is an example of a continuous distribution of resistive material. That should give you a hint of using calculus. So instead of R = rho * L/A you will get
[tex]dR = \rho\frac{dL}{A}[/tex]
and proceed.
and proceed.
but what is the expression for A? area of this box would be (b-a) times ...??
From first principles the current density j (current per unit area) is
[tex]j = \sigma E = -\frac {1}{\rho} \frac {\delta V}{\delta r}[/tex]
where [itex]\sigma = 1/\rho[/itex] is the conductivity. Now
[tex]j = \frac {I}{4\pi r^2}[/tex]
for your problem and it follows that
[tex]\Delta V = -\int_{a}^{b} \frac {\rho I}{4 \pi r^2} \delta r[/tex]
or
[tex]\Delta V = \frac {\rho I}{4 \pi} \left( \frac {1}{a} - \frac {1}{b}\right)[/tex]
The resistance is just the right hand side divided by I. Notice that in your original expression the units are not correct which is a hint that something was amiss.
or
thank you very much!
that wasn't an approach i was thinking about but it works , and how!
thank you very much again!
The dR approach is equivalent to Tide's approach. When I gave you the hint to use calculus, you should've realized that I am referring to the area of a spherical surface which would be 4pi (r squared).
