How Do You Calculate This Double Summation?
  • Level: Graduate
  • Thread starter Thread starter sabbagh80
    Summation
11 replies · 6K views · last reply
sabbagh80
Hi,
Can every body solve this problem in terms of [itex]a[/itex] and [itex]b[/itex].
[itex]e^{-(a+b)}\sum _{n=0}^{\infty} \frac{a^n}{n!} \sum_{m=0}^{n}\frac{b^m}{m!}[/itex]
Thanks in advance for your participation.
hi sabbagh80! :smile:
hmm … looks a bit like a binomial expansion, doesn't it? :rolleyes:
it's over all pairs (m,n) with m ≤ n
try rearranging the ∑∑ into a ∑∑ over different variables :wink:​
I mean that is it possible to further simplify this expression or maybe rewrite it by a more known functions. Because computing this expression in a long loop is time consuming process. isn't it?
sabbagh80 said:
I mean that is it possible to further simplify this expression …
yes … try rearranging the ∑∑ into a ∑∑ over different variables :smile:
Are you meaning
*. e^−(a+b) * ( ∑a^n/n!) (∑b^m/m!)
or
**. e^−(a+b) * ∑ (a^n/n! (∑b^m/m!) )
For *, we can evaluate each sum separately, then multiply the result. Hint: try a power series formula sheet. * simplifies beautifully.
I suspect you mean **, where the b_m/m! sum gets evaluated first. Then multiplied by a single "a" term.
Arggh, almost had it until I realized the sum b^m/m! is not an infinite number of terms, but n terms.
Can everybody show me how could I do the above suggestion?
nickalh said:
Are you meaning
or
What is your meaning, I am confused!
Let me first say that even with tinytim's suggestion, I still haven't figured this out!
Anyway, the idea is straightforward enough. If we sketch out the area over which you are summing with m on the horizontal axis and n on the vertical, then we see the sum is taken over all pairs (m,n) on or above the line m=n (or the line y=x if that is any clearer). Now at the moment, your sum is calculated by picking a value for n and then summing the first n terms of bm. So, using our picture, you're summing horizontally. However, you could also sum vertically, or by diagonals parallel to the line m=n or by diagonals parallel to m=-n.
That said, I'm not sure which method will make things easier, though tinytim's comment makes me think it might be the last one I mentioned...
hi spamiam! :smile:
spamiam said:
… though tinytim's comment makes me think it might be the last one I mentioned...
yup …
instead of summing over all values of m and n,
sum over all values of m and m+n :wink:​
sabbagh80 said:
Hi,
ok. didn`t see the `n`.
matphysik said:
Answer =1.
It is a cute joke!
m is from 0 to n not to infinity.
by the way, thanks for your participation.
sabbagh80 said:
Hi,
The outline of the derivation is as follows:
First, check that the double sum converges!
Next, the summation from m=0 to m=n. Rewrite this as the difference of the summation from m=0 to ∞ and the summation from m=n+1 to ∞. The first member of this difference is eᵇ. For the 2nd member set p:=m-(n+1), where p runs from zero to ∞.
We may differentiate this 2nd member (n+1) times (= eᵇ). Then (indefinite) integrate this (n+1) times to get,
(*)- eᵇ + c₁bⁿ/n! + c₂bⁿ⁻¹/(n-1)! +...+cⁿ⁺¹,
where the `c` are integration constants which may all be set equal to unity.
Last, multiply Σaⁿ/n! with each term of (*) and sum each resulting term to get the result.
NOTE: Nobody cares about making computations such as this by hand anymore. They do this by computer.
Addendum: See, for example, the work of Doron Zeilberger.
