How Do You Determine if a Meteoroid Has an Open Orbit?
The discussion revolves around determining whether a meteoroid has an open orbit based on its velocity and distance from the sun. The subject area includes gravitational physics and energy calculations related to celestial mechanics.
  • Participants discuss using energy calculations to determine the meteoroid's energy and compare it to the energy required to escape the sun's gravitational influence. There are attempts to apply kinetic and potential energy formulas, with some questioning the relationship between the calculated energy and escape velocity.
Participants are actively exploring the problem, with some providing calculations and others seeking clarification on the relationship between energy, escape velocity, and the meteoroid's status relative to the solar system. There is recognition of the need to use energy calculations as specified in the problem statement.
Some participants express confusion regarding the calculations and the interpretation of energy values, particularly in relation to escape velocity and the implications of the meteoroid's energy being zero.
Workout
A meteoroid with a velocity (when the effect of the Earth's gravity has been eliminiated) of 49.9 km/s when it is at a distance of 1.50x10^11m from the sun.
(a) Using energy calculations show that this object has an open orbit and is therefore not restricted to our solar system
(b) Calculate what the velocity of this meteoroid would be when it was infinitely far away from the sun
v = sqrt (2GM/r)
For (a) I just plugged in v = 49 900 m/s
G = constant
r = 1.50x10^11m
And I solved for M which was 9.33x10^30 kg which doesn't equal the Earth of the mass so that shows that it isn't part of our solar system.
Then for (b) I used the same equation I used above and plugged in r = infinity which eventually leads to 0. So does the v eventually go to v = 0 m/s?
The first part of the problem says to use energy calculations. So, find the meteroid's energy, and compare it to how much energy is needed to escape the Sun. Don't forget to include kinetic and potential energy.
I used the energy formula E = KE + U
= 1/2mv^2 - GmM/r
E = 1/2v^2 - GM/r
Then I plugged in my knowns
v = 49900 m/s
G = 6.67x10^-11
M = 5.98x10^24 kg
r = 1.50x10^11m
So the energy of the meteroid in the Earth's circuit should be 1.25x10^9 J
So for the comparison do I compare it to the escape velocity? Because it doesn't workout because E = 0. A little confused.
Workout said:
Here I assume E = 0 because it said that the meteroid is not in our solar system so it's escape velocity right? So then my formula provided is the energy formula for escape velocity.
You have the formula for escape velocity:
ve = sqrt(2 G M / r)
and the velocity of the meteoroid is given:
vm = 49 kph
so what do you think the next step should be to determine if the meteroid has achieved escape velocity?
For the last part of the problem, you could also use the formula for gravitation potential or gravitational potential energy versus distance from the sun.
Do I get the escape velocity and compare it to the velocity of the meteoroid?
What would the energy of an object at that location at escape velocity be?
Yes.
rcgldr said:
Yes.
Thank you.
rcgldr said:
Yes.
Except that the problem says to use energy calculations.
So that would change this to
1/2 m ve2 = G M m / r = - GPE of meteroid
1/2 m vm2 = 1/2 m (49900)2 = KE of meteroid
  • · Replies 39 ·
