- 611
RandallB said:I don’t care how you spin what Zeilinger said – it comes down to agree with just what Dr C says in post #27.
I understand he is an important guy, but proof by authority does not work for me but I had not been able to find a documented experiment that demonstrates the point.
I disagree. One of the important restrictions Zeilinger mentions in his paper is that the interference pattern will vanish for perfect correlations between both photons. However this perfect correlation is only possible in a near-field setup. Going to far-field conditions automatically destroys your entanglement (see below), so I think Zeilinger is well aware of using a near field setup. So let me paraphrase the wording of Zeilinger again: There is no possible setup, in which you can maintain entanglement and go to far-field conditions simultaneously.
RandallB said:It focus on the pattern observed in Fig 2.
Unless you can explain how any a)more, b)less or c)different photons will show at the Ds detector by not limiting the count there with Dp correlations (IE turn Dp off & count all Ds hits) how can it not show the same interference pattern.
You will see more photons. In coincidence count experiments there are in fact two interference patterns. One is shown here, which is the result of moving the Ds detector. The detector Dp is stationary and small. You will see another interference pattern if you leave Ds stationary and instead move Dp and this interference pattern will be exactly out of phase with the other one. This has been shown in the Dopfer thesis and also in the Kim DCQE paper if I remember correctly. So by detecting all photons, which is equal to increasing the size of Dp you will see the superposition of both patterns, which is a simple peak without interferences.
DrChinese said:It seems to me you can take separated entangled photons and then aim them at a double slit while preserving their momentum entanglement. You should be able to aim them with sufficient precision (and the appropriate angular size) to get an interference pattern - if there is one to get. I don't think an interference pattern will form in such circumstances, and I think that is the point that Zeilinger is making.
I don't think so. The range of possible k-values and therefore also momentum values narrows strongly if you increase the distance between double slit and the SPDC crystal. At some point you just have a momentum filter and the concept of entanglement is not meaningful anymore. As soon as you reach this distance the entanglement vanishes and at this point the single photon interference pattern starts to show up.
Another light source might however show an interference pattern at the same distance from the slit. This is a question of spatial coherence.
