How do you dissolve plaster of paris
  • Thread starter Thread starter joeoswald
    Dissolve
The discussion revolves around methods for dissolving plaster of Paris, particularly in the context of home renovation. Participants share various chemical approaches and practical suggestions for removing plaster from brick surfaces.
  • One participant reports difficulty in removing plaster of Paris using hydrochloric acid and caustic paste, seeking accessible and affordable alternatives.
  • Another participant suggests renting a sand blaster as a potential solution.
  • A different viewpoint expresses skepticism about using acids, proposing that scraping may be the most effective method instead.
  • One participant proposes using 30% hydrogen peroxide or perchloric acid followed by hydrofluoric acid, but acknowledges the risks involved.
  • Another participant challenges the effectiveness of acids, claiming that they do not dissolve plaster of Paris and may even complicate removal. They advocate for using sodium bicarbonate in warm water as a more effective solution.
Participants express differing opinions on the effectiveness of acids versus basic solutions for dissolving plaster of Paris. There is no consensus on the best method, and multiple competing views remain regarding the appropriate chemical approaches.
Some participants reference personal experimentation with various chemicals, indicating that results may vary based on conditions and specific formulations used. The discussion highlights the complexity of chemical interactions involved in dissolving plaster of Paris.
joeoswald
We have purchased a federation style home, which had the front painted white. During the removal process, we found that underneath several layers of paint, plaster of paris had also been applied in a random way, and is proving very hard to remove. We have tried HCL, as spirit of salts, but no luck. Also tried a caustic paste, but it still won't shift. Any product would have to be readily accessible, and relatively cheap. The house isn't that big, and it only the front of the house, but there are still a lot of bricks that need plaster removed. Any ideas?
Thanks
Chemistry news on Phys.org
Thanks Kracatoan, we will try it over the weekend.
Can you rent a sand blaster?
Don't believe in acids. Muriatic perhaps, but even then I would not expect outstanding results, and it can eat through everything else first. Sadly, as far as I know scraping is the best option.
Hmm, if it were up to me, I'd apply 30% Hydrogen Peroxide or Perchloric acid then follow it up with some Hydrofluoric Acid. That's asking for a pandora's box of trouble though. Also, it may require some kind of portable microwave generator for best results... :)
When I think about the results I think it would be easier and safer to rent a bulldozer.
Don't forget to insure the house before trying.
I am so surprised that the people on this forum, and other forums, obviously don't have a clue about the chemistry of plaster of paris. I read in so many places things like "uh, try some kind of acid..."
So I have a lot of concentrated chemicals on hand and did lots of experiments with all kinds of acids, both dilute and concentrate, under many conditions and determined that acids do not dissolve Plaster of Paris in any way, but sometimes make it harder.
The chemicals which dissolve plaster of paris are on the basic end of the PH scale, not acid. I first had some success with potassium cyanide, but what really worked better than anything is Sodium Bicarbonate. Makes sense. The sodium in baking soda hooks up with sulfur in the plaster, and the carbon hooks up with the calcium in the plaster.
TO BEST DISSOLVE PLASTER OF PARIS PLACE IT IN WARM WATER WITH LOTS OF BAKING SODA. :wink:
Don't use any acids or it will only defeat the process.
Now what really amazes me is that the answer is so simple and safe, and surely some people must know it, but it apparently cannot be found on the internet, until now.
14K
36K
  • · Replies 21 ·
  • · Replies 59 ·
  • · Replies 24 ·
33K
  • · Replies 16 ·
