How do you find the equation of a Cubic function given 5 points? (no zeros)?
To find the equation of a cubic function given five points, one method involves creating a system of equations based on the polynomial form ax^3 + bx^2 + cx + d. Participants discussed the elimination/substitution method but also highlighted the finite difference method as a potentially easier alternative. The finite difference method involves calculating successive differences of the function values, which can reveal the coefficients of the polynomial more efficiently. One user expressed gratitude for discovering this method, noting a significant reduction in time spent solving the problem. Overall, the discussion emphasizes the utility of different mathematical approaches to solving polynomial equations.
srizen
what the questions asks is that i need to find the equation of a polynomial with these given points:
1,1
2,-3
3,5
4,37
5,105i know that one way to solve is by creating 5 equations then solve for ax^3+bx^2+cx+d using the elimination/substitution method.
however is there another, much easier way of doing this question?
ax^3+bx^2+cx+d
1= a+b+c+d
-3=8a+4b+2c+d
5= 27a+9b+3c+d
37=64a+16b+4c+d
108=125a+25b+5c+d
fixed, yes, my mistake
srizen said:
1= a+b+c+d
-3=8a+4b+3c+d
5= 64a+16b+5c+d
37=64a+16b+5c+d
108=125a+25b+5c+d
Three of the equations are wrong. They should be
1= a+b+c+d
-3=8a+4b+2c+d
5= 27a+9b+3c+d
37=64a+16b+4c+d
108=125a+25b+5c+d
Also, you don't need the last equation, because there are 4 unknowns.
As for other methods, there's the finite difference method, but I don't think it will help for this particular problem (because you already told us that this is a cubic).
1= a+b+c+d
-3=8a+4b+2c+d
5= 27a+9b+3c+d
37=64a+16b+4c+d
108=125a+25b+5c+d
fixed, i typed the equations too fast
True, but I got the coefficients fairly quickly using a difference method.
Actually, after playing around a bit with this, I got the result with two different difference methods.
what exactly is the difference method?
i ask because I've tried this question, and i kept getting it wrong.
Make a table of differences
\begin{array}{|c|c|c|c|c|c|c|c|c|} \hline <br /> \quad i \quad &amp; \quad x_i \quad &amp; \quad f(x_i) \quad &amp;\quad (\Delta^1)_i \quad &amp;\quad (\Delta^2)_i \quad &amp; \quad (\Delta^3)_i \quad &amp; \quad (\Delta^4)_i \quad \\ <br /> \hline <br /> &amp; &amp; &amp; &amp; &amp; &amp; \\<br /> 1 &amp; 1 &amp; 1 &amp; -4 &amp; 12 &amp; 12 &amp; 0 \\<br /> &amp; &amp; &amp; &amp; &amp; &amp; \\<br /> 2 &amp; 2 &amp; -3 &amp; 8 &amp; 24 &amp; &amp; -- \\<br /> &amp; &amp; &amp; &amp; &amp; &amp; \\<br /> 3 &amp; 3 &amp; 5 &amp; &amp; &amp; -- &amp; -- \\<br /> &amp; &amp; &amp; &amp; &amp; &amp; \\<br /> 4 &amp; 4 &amp; 37 &amp; &amp; -- &amp; -- &amp; -- \\<br /> &amp; &amp; &amp; &amp; &amp; &amp; \\<br /> 5 &amp;5 &amp; 105 &amp; -- &amp; -- &amp; -- &amp; -- \\<br /> &amp; &amp; &amp; &amp; &amp; &amp; \\<br /> \hline \end{array}
Where: (\Delta^1)_i=f(x_{i+1})-f(x_{i})\,,
(\Delta^2)_i=(\Delta^1)_{i+1}-(\Delta^1)_i
etc.
See if you can fill in the rest.
If f(x) is truly a cubic function then the Δ3 column will all be the same.
Fill out a similar Table for g(x) = x3 . The Δ3 column will all be 6's.
What do you suppose that means about the x3 coefficient of f(x) ?
etc.
OMG! i love you forever, i had no idea this method existed, i already solved through almost an hour of writing matrices, with this i solved it in 3 minutes. thank you!
