How do you integrate (x)/(x-1)
  • Thread starter Thread starter amanda_ou812
    Integrate
The integration of the function S x/(x-1) dx can be effectively solved using the substitution method. By substituting u = x - 1, the integral simplifies to ∫(u + 1)/u du, which can be easily integrated to yield x + ln(x - 1) + C. Attempts to use Integration by Parts were ineffective, highlighting the importance of recognizing suitable substitution techniques for integration problems.
  • Understanding of basic integration techniques
  • Familiarity with Integration by Parts (IBP)
  • Knowledge of substitution methods in calculus
  • Ability to manipulate algebraic expressions
  • Study substitution methods in calculus
  • Practice Integration by Parts with various functions
  • Explore advanced integration techniques, including partial fractions
  • Learn about integration tables and their applications
Students studying calculus, educators teaching integration techniques, and anyone seeking to improve their problem-solving skills in mathematical integration.
amanda_ou812
How do you integrate S x/(x-1) dx
IBP
I tried using Integration by Parts with u= x/(x-1) and dv = dx and that did not work out. Then I tried using u= 1/(x-1) and dv = xdx but that did not work either.
A google search said "Just use the substitution u = x+1, then replace dx with du and you get u+1/u = 1 + 1/u which you can integrate to give u + ln u, thus = x-1 + ln(x-1)". But I am pretty sure that you can't just add +1 to the numerator like that.
I also know that it can be done using tables but is there a way not to use tables? Did I do my integration wrong?
Thanks
Likes Mikael Lindberg
You don't add +1 to the numerator. We do the substitution u=x-1. What happens if you do that substitution??
Hint Hint:
\frac{1}{x-1}+\frac{x-1}{x-1}=\frac{x}{x-1}
You can even do it without substitution by changing the equation to (x)/(x-1) = (x-1+1)/(x-1) = 1+1/(x-1), then integrating to get x+ln(x-1)+C.
Wow! All 3 posts within a minute!
Perhaps this will make it clearer,
Suppose u=x-1. Then clearly du=dx. But notice also that u+1=x by the first equation. Therefore, the integral becomes,
\int \frac{u+1}{u}du
Now, it is trivial. :)
We're all just so stoked about integration, we can't resist. If only all students shared our passion for integration... ;)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
  • · Replies 105 ·
