How Do You Prove the Multivariable Chain Rule?
4 replies · 2K views · last reply
Lambda96
Use the chain rule to show the followin is true ##D(f+g)=D(f)+D(g)##
Multivariable Chain rule
Hi,
Im completly lost regarding the following exercise:
Printed text of a homework exercise: let k, m, n be natural numbers and U open in R^k; a linear map A: R^n to R^m has differential DA = A; part a) asks to show that for differentiable f, g: U to R^m, f + g has differential D(f+g) = D(f) + D(g).
Unfortunately, I don't understand how to prove the statement using the chain rule. The chain rule is always used if there is a composition, i.e. ##f\circ g=f(g(x))## then I first have to calculate ##g(x)## and insert this result into ##f##, but D(f+g) is a operation and not a composition.
Lambda96 said:
Homework Statement: Use the chain rule to show the followin is true ##D(f+g)=D(f)+D(g)##
Relevant Equations: Multivariable Chain rule
Hi,
The addition is the second function, say ##A(f,g)= f+g.## Then we get ##D(f+g)=D(A(f,g))=(D\circ A)(f,g)## and ##D(f)+D(g)= (D(A))(D(f),D(g)).##
Thank you fresh_42 for your help 👍, now the task makes more sense
If I now apply the chain rule to the expression ##(D \circ A)(f,g)##, the result should be ##D'(A(f,g))\cdot A'(f,g)##, right?
I'm not sure how to write it best and it is all about notation.
With ##A(f,g)=f+g## we have
\begin{align*}
A(\alpha (f,g))&=A(\alpha f, \alpha g)=\alpha f+\alpha g=\alpha(f+g)=\alpha A(f,g)\\
A((f_1,g_1)+(f_2,g_2))&=A((f_1+f_2),(g_1+g_2))=(f_1+f_2)+(g_1+g_2)\\
&=(f_1+g_1)+(f_2+g_2)=A(f_1,g_1)+A(f_2,g_2)
\end{align*}
and ##A## is linear. Therefore we have ##DA=A.## Finally,
D(f+g)=D(A(f,g))=DA(D(f,g))=DA(D(f),D(g))=A(D(f),D(g))=D(f)+D(g)
Please note to every equation sign which property we have used!
1. ...
2. ...
3. ...
4. ...
5. ...
