How Do You Reverse Projections to Interpret Geological Maps?
  • Thread starter Thread starter rahuldg11
The discussion focuses on the challenges of interpreting geological maps, particularly regarding the understanding of discontinuity surfaces and the process of reversing projections to visualize subsurface geology. Participants share their experiences and strategies for improving map interpretation skills.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant expresses difficulty in interpreting geological maps and seeks assistance.
  • Another participant requests clarification on the specific problems being faced, suggesting that examples would help.
  • A participant outlines their understanding of interpreting topography and lithological units but struggles with details of discontinuity surfaces.
  • One suggestion is to draw a cross-section of unclear areas to aid understanding using topographic and dip information.
  • Another participant questions how to understand discontinuities solely from dip directions and relative dip amounts.
  • A participant emphasizes the importance of visualizing the 3-D structure from the 2-D map by reversing projections, explaining how synclines and unconformities can be identified.
  • Common sense and practice are suggested as key components in developing interpretation skills.
  • There is a lack of clarity from some participants regarding the specific misunderstandings being addressed.
Participants express varying levels of understanding and approaches to interpreting geological maps, with no consensus on the specific challenges faced or the best methods to overcome them.
Some assumptions about the participants' prior knowledge and the definitions of geological terms may not be fully articulated, leading to potential misunderstandings in the discussion.
Individuals interested in geology, particularly those learning to interpret geological maps or seeking to improve their skills in visualizing subsurface structures.
rahuldg11
I have real problems in interpreting geological maps. Can somebody help me ??
You need to first explain what you are having a problem with. Can you give examples?
Can you tell me the steps to interpret a map? i can more or less understand the topography, then identify the litho units. The main problem i have is with the discontinuity surfaces. Even if i am able to identify them, i cannot get the details of the surfaces.
I always found it helpful to draw a cross section of an area that looks unclear. Use the topographic and dip information given, see if that helps.
yes, that is not a bad thing to do. But how do u understand the discontinuities from the map itself, just by looking at the dip directions and relative dip amounts ?
honestly I'm not quite sure what it is you don't understand so I can't really help.
Remember that a map is a section. It is an intersection of the ground with the subsurface geology. A syncline with an axis dipping at 20 deg projects an outline of itself onto the 3-D - ground surface and hence onto the 2D map surface. You just have to reverse those projections in your mind in order to envisage the 3-D structure.
Unconformities are easily recognisable, since one lithology will cut across several others. Unless we are dealing with thrust faults, or igneous intrusions then the truncated lithologies are the older ones.
It's really just a mater of putting together common sense ideas like that and practising the art of interpretation.
Apart from that, I'm with Matt - I don't understand what it is you don't understand.
  • · Replies 20 ·
