How Do You Solve a Glancing Elastic Collision in Physics?
  • Thread starter Thread starter air4ce
    Momentum Physics
The discussion revolves around a problem involving a glancing elastic collision between two balls, specifically a cue ball and a target ball. The cue ball is initially moving and collides with the target ball, which is at rest. Participants are exploring the concepts of momentum and kinetic energy conservation in the context of this collision.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the definitions of elastic collisions and the conservation principles that apply. They explore the relationships between the velocities of the balls post-collision and attempt to set up equations based on conservation laws. Questions arise regarding the setup of momentum equations in both x and y directions, as well as the application of the Pythagorean theorem to relate the components of the velocity vectors.
The discussion is active, with participants providing guidance on separating momentum into components and using kinetic energy conservation. There is an ongoing exploration of the relationships between the various quantities involved, and multiple interpretations of the problem setup are being considered.
Participants note that all masses are equal, which simplifies the equations. There is also a mention of the angle of deflection for the cue ball, which introduces a ratio between its velocity components. Some participants express uncertainty about how to proceed with the limited information available.
air4ce
A cue ball traveling @ 4m/s makes a glancing elastic collision with a target ball of equal bass that is initially at rest. The cue ball is deflected @an angle of 30°. Find the angle between the two velocity vectors; and the speeds of the two balls post collision.
[tex]KE= 1/2mv^2 \\<br /> P=mv[/tex]
[itex]m_1=m_2 \\<br /> m_1*v_1=m_1*v_{1f} + m_1*v_{2f} \\<br /> v_{1f}=4-v_{2f}[/itex]
Stuck here. I know I have to use Kinetic Energy, but how?
What's the definition of an elastic collision?
One where both momentum and kinetic energy are conserved.
So use conservation of kinetic energy to apply another constraint to the problem.
[itex] .5m_1v_{1o}^2 =.5m_1v_{1f}^2+.5m_1v_{2f}^2 \\<br /> v_{1o}^2=v_{1f}^2+v_{2f}^2 \\<br /> v_{1f}=\sqrt{v_1^2-v_2f^2} \\[/itex]
Am I on the right track?
Yes and also don't forget to separate conservation of momentum into both x and y. Write a conservation equation for both directions and use the results of that as well.
So the horizontal momentum cancels and the vertical momentum totals the momentum of the cue ball?
Since the angle of cue ball is 30, I use the two equations to find [itex]v_{1fy}[/itex] and then solve for the horizontal? That's going to be equal and opposite to the struck ball's x velocity, so I have both velocities, use pythagorean theorem and I'm done? Check the logic please!
well when we write out the momentum in x and y we get
[itex]x: mv_{1,x} = mv^{'}_{1,x} + mv^{'}_{2,x}[/itex]
and
[itex]y: 0 = mv^{'}_{1,y} + mv^{'}_{2,y}[/itex]
where the prime denotes "after the collision"
so
[itex]mv_{1} = mv^{'}_{1} + mv^{'}_{2}[/itex]
is really only half of it. But can you see how you can use pythagorean's theorem to relate the x and y components to the magnitude of the vector?
I think your X and Y's are flipped, but yeah I get the point. But I only know two of the 4 quantities, the ones before the collision, and one KE equation. How does that work?
Since all the masses are equal we can do away with them in the various expressions. Similarly, we can do away with the (1/2)m's in the kinetic energy terms. Call the initial velocities v and final velocities u, with appropriate subscripts for the x and y components, of course.
The given departure angle for the cue ball gives you a relationship between its y and x velocities as it departs. Namely, the ratio is tan(30°), or ##1/\sqrt{3}##, so that:
$$\frac{u1_y}{u1_x} = \frac{1}{\sqrt{3}}$$
Now, what does conservation of momentum have to say about the relationship between the y-velocities u1y and u2y ?
And what does it say about about the sum of the x-velocities?
That's three equations already, and conservation of KE hasn't been considered yet...
